Oh freaking great...bolts are missing from my turbo
They were there before, here's a pic of when they were there...when I first had the turbo put on.
The one on top is coming out...only reason it wasn't gone, is because it didn't have enough room to come off...as for the others, they're gone...so what the hell are they there for
I've only had the turbo for like 3 weeks and where can I get new ones?
definitely. there are actually only two missing, I was a little overreactive...hahaa, I'll just take one out, go to the department store and get some new ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 02SilverSiHB »</TD></TR><TR><TD CLASS="quote">
How do you like it? My Dad has one and was looking into turbo
</TD></TR></TABLE>How do you like it? My Dad has one and was looking into turbo
the fun just doesn't stop...I took one bolt out, and found that I had three bolts that would fit (found them in my tool box)...which I needed three, as three were gone.
So I put the other one back in that I took out, and go to put the other three in....well, first, the one bolt that was hanging out, was hanging out because it broke in ******* half...it just fell out when I tried to mess with it.
So, that means there's still some bolt left in there...and you can see it, plain as day. So I'm not putting a bolt in that one. I go to the last two of the three holes...same thing. Except one is not as bad and I rigged it with a bolt and a nut (oversized nut) that would help for the space left over from when trying to tighten the bolt.
So...yippy, my ******* life story, anything that could go wrong, could go wrong for me. I haven't noticed any boost leak at all and the car pulls hard still...so, the only way to get it fixed, is to go...allllll the ******* way back up to dallas...boy oh boy
when you finally do get all your bolts back and get those broken off ones out, warm the car up to normal operating temp. Hell, even rev it a bit with the hood popped and tighten the bolts while the turbo is hot. Hopefully that'll keep the bolts from backing out on you again. Or get yourself some lock washers while you're at Home Depot buying your bolts.
Unless you can get a hold of a piece of the bolt with some vise grips. Persoanlly I'd take it to a machine shop and havethem do it. Aturbo is an expensive piece of metal to "test" your drilling skills on. There's a post floating around here from a guy that snapped off his oil pressure sensor AND an easy out. He'll be taking his block to a machine shop (hopefully).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IslandSi »</TD></TR><TR><TD CLASS="quote">Unless you can get a hold of a piece of the bolt with some vise grips. Persoanlly I'd take it to a machine shop and havethem do it. Aturbo is an expensive piece of metal to "test" your drilling skills on. There's a post floating around here from a guy that snapped off his oil pressure sensor AND an easy out. He'll be taking his block to a machine shop (hopefully).</TD></TR></TABLE>
yeah, I think I'll just go back to vsv and let them take care of it...and I can't use vise grips, the broken bolts are too far in, can't get a grip on them
You might be able to get the broken bolts out with this kit from Craftsman. But it doesn't look like you'd be able to with the turbo still on the car though.
http://www.sears.com/sr/javasr...55000
Who is Mr Robot?
most of the time the bolts are harder than the drill bit (Don't ask) my dad had the same problem on his powerstroke diesel, some blue high-temp loctite fixed it.
I also have the sc34. So far my bolts are still tight. I did lose my bov nuts the first day. Damn rfl. Turbo means more maintinence, so you better be ready.
I have a missing bolt as well...of course its the bolt that I had to shave. I just left it missing, nothing seems to be affected by it being gone.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97hb »</TD></TR><TR><TD CLASS="quote">I also have the sc34. So far my bolts are still tight. I did lose my bov nuts the first day. Damn rfl. Turbo means more maintinence, so you better be ready.
yeap, I need to start making it a weekend thing to at least check over this stuff...I bet if I had, I would have caught this before it became such a problem...definitely my fault
</TD></TR></TABLE>yeap, I need to start making it a weekend thing to at least check over this stuff...I bet if I had, I would have caught this before it became such a problem...definitely my fault
Heh, I had the same bolts came off, two of them but I didn't even know about it as the turbo sits quite low and its not clearly visible until I had my block rebuilt they told me..
Get use to it, its turbo life.....nuthin but grief...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vietjdmboi »</TD></TR><TR><TD CLASS="quote">i suggest using some anti-seize on those bolts so it doesnt happen again.</TD></TR></TABLE>
wake up and smell the roses...anti-seize is a lubricant...maybe you meant thread locker?
what kinda setup do you have to get that that 301whp? My engine is being rebuilt and i was just seeing what kinda numbers i can expect...
EP3
EP3
I have stock internals, stock clutch, stock muffler, and the rest is 2.5" piping at the midpipe, downpipe. I have a sc34 turbo with precision fmic...and tial wastegate and tial bov.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost psycho »</TD></TR><TR><TD CLASS="quote">
wake up and smell the roses...anti-seize is a lubricant...maybe you meant thread locker?</TD></TR></TABLE>
Yeah, I was thinking he meant thread locker
Two days after I was turbo, I was checking all the bolts and caught a couple of those loosening off... I thought I had forgotten to tighten them... now I know
heheh...
heheh...
thanks for the link though!
