Need help about to put sugar in my gas tank!!!!!!!!!!!!!!!!!!!!!!!!
I have a all motor LS automatic. I have had the thing tuned 3 times and $1000 later I still have the same problem. I has a huge hessitation like the rev. limiter during the first 3K rpms. I have checked all vaccum, replaced intake gasket, and checked all the sensors. I have no check engine light. Anyone have any advice.
cause he likes the taste of course geeeeez why wouldnt anybody else want sugar in there tank
check your ecu
check your ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GChambers »</TD></TR><TR><TD CLASS="quote">Why the hell would you put sugar in your tank?</TD></TR></TABLE>
The exhaust byproducts and sugar fuse, to form an aroma similar to that of donuts. This causes policeman to go into a state of confusion. Leaving just enough time to make an escape.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16aDasher »</TD></TR><TR><TD CLASS="quote">
The exhaust byproducts and sugar fuse, to form an aroma similar to that of donuts. This causes policeman to go into a state of confusion. Leaving just enough time to make an escape. </TD></TR></TABLE>
LMAO Now thats funny stuff.
It's probably an ecu or distributor problem...
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
LMAO!!!!
</TD></TR></TABLE>LMAO!!!!
From: That's the wrong tone... I'm Skunk2 certified.
wouldn't the gas dissolve the sugar? i've gotten gas on my greasy 'worked on the car' hand before, and the grease came right off. I imagine sugar would be no match for pressurized gasoline.
On a serious note, yes, it's probobly your timing. Make sure your cam(s) and crank are lined up correctly. Cam gears like to slip a tooth or two on the timing belt when you rev too high.
By the way, removing your rev limiter is useless on a stock engine. It's there for a reason. Cam gears slip, and valvetrains blow up when you exceed the engines redline. Besides, you don't even make power up there anyways. It's not like Honda had to rev limit the engine because people were getting air on freeway on ramps.
Modified by MugenDude at 5:27 PM 10/12/2004
Modified by MugenDude at 5:32 PM 10/12/2004
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenDude »</TD></TR><TR><TD CLASS="quote">wouldn't the gas dissolve the sugar? i've gotten gas on my greasy 'worked on the car' hand before, and the grease came right off. I imagine sugar would be no match for pressurized gasoline.
You are correct, the sugar would dissolve in the gas. It is harmless to the engine.
juanito297
15
Nov 8, 2008 04:01 PM
civiccrazy93
Nov 16, 2004 12:06 PM
