questions about my new garret t3
Old Oct 11, 2004 | 09:39 AM
antiJDM's Avatar
Default questions about my new garret t3
i was lucky to find this turbo on a 86 or 87 ford thunderbird turbo coupe, it looks freshly rebuilt, no shaft play, spins freely..well my question is..
what is the stock internal wastegate spring rated at?
i've also heard different opinions on the water cooling...one of which to just leave the inlet/outlet unplugged..dont run coolant lines, somebody else told me run the lines, and another person said plug them..
all help is appreciated.
Old Oct 11, 2004 | 11:02 AM
antiJDM's Avatar
anybody?
Old Oct 11, 2004 | 12:19 PM
Rod Short's Avatar
Default Re: (2thousandcivic)
Probably not a lot of people here that will know anything about that. I messed with some SVO's which had similat T3/T4 setups. I believe these would run about 14-psi on premium gas. You may want to try the SVO bulletin board. Just do a word search on Mustang SVO & you should fine the link. Hope this helps.
Rod Short
Sales Manager
Precision Turbo
Old Oct 11, 2004 | 12:24 PM
antiJDM's Avatar
Default Re: (Rod Short)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rod Short &raquo;</TD></TR><TR><TD CLASS="quote">Probably not a lot of people here that will know anything about that. I messed with some SVO's which had similat T3/T4 setups. I believe these would run about 14-psi on premium gas. You may want to try the SVO bulletin board. Just do a word search on Mustang SVO & you should fine the link. Hope this helps.
Rod Short
Sales Manager
Precision Turbo</TD></TR></TABLE>
14psi lord...thanks for help man..you have a link for that svo board?
Old Oct 11, 2004 | 01:18 PM
thelate1's Avatar
i was told my internally gated t3 is set to 7-8psi. i guess they can very though. if the shaft of the actuator is threaded then i believe it's adjustable.
hth
Old Oct 11, 2004 | 06:41 PM
antiJDM's Avatar
Default Re: (thelate1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thelate1 &raquo;</TD></TR><TR><TD CLASS="quote">i was told my internally gated t3 is set to 7-8psi. i guess they can very though. if the shaft of the actuator is threaded then i believe it's adjustable.
hth </TD></TR></TABLE>
all t3's arent created equal...chances are if it is adjustable it is a volvo turbo.
Old Oct 11, 2004 | 09:36 PM
shrug's Avatar
10psi
Old Oct 11, 2004 | 09:43 PM
antiJDM's Avatar
Default Re: (shrug)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shrug &raquo;</TD></TR><TR><TD CLASS="quote">10psi </TD></TR></TABLE>
thats a lot of what i've been getting, but i was told that the automatics and manuals had different sized compressors..
even jeff on hmt agreed to the 10psi that somebody posted.
im thinking that i will just end up cutting and threading on a long nut to make a home made boost controller...or break out my money and buy a real manifold and wastegate and trash the internal wg.
Whatever
Oct 16, 2008 10:08 AM
aimbot
Apr 13, 2007 05:44 PM
I.C.C.
Mar 7, 2007 07:20 PM
Jedi Jake
Feb 20, 2007 04:56 PM
jerbear!
Oct 28, 2004 03:16 PM
