Help!
Old Oct 11, 2004 | 09:21 AM
encognito's Avatar
Default Help!
Im replacing my timing belt on my 2000 ITR. I couldn't break the tensioner bolt loose(it hasn't ever been touched untill now.I broke 3 sockets, then tried a chizzle and now the head on the bolt is messed up. Any advice?
Old Oct 11, 2004 | 10:22 AM
mstewar's Avatar
Default Re: Help! (encognito)
you used a chisel on it?! what for?
any chance you can get some vicegrips on it and then use a pipe or something to give better torque/leverage? how did you break 3 sockets?
otherwise, the only thing I can think to do is to maybe drill a hole in it and use a screw extractor..
i assume you soaked it in PB blast(or equivalent) after you initially had trouble removing it?
it's not reverse threaded or locked in some way is it? i can't remember offhand..
Old Oct 11, 2004 | 10:59 AM
Willard's Avatar
Default Re: Help! (mstewar)
mine was tight.. but not that tight.
Are you sure it is not the crank pulley bolt?
I did break a socket on that POS.
Old Oct 11, 2004 | 06:05 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by encognito &raquo;</TD></TR><TR><TD CLASS="quote">Im replacing my timing belt on my 2000 ITR. I couldn't break the tensioner bolt loose(it hasn't ever been touched untill now.I broke 3 sockets, then tried a chizzle and now the head on the bolt is messed up. Any advice?</TD></TR></TABLE>
Bolt extractor. Or at least get an impact socket so you stop breaking them.
http://www.irwin.com/irwin/con...00005
Old Oct 11, 2004 | 06:17 PM
sackdz's Avatar
Default Re: Help! (ccfries)
man you gotta be on the wrong bolt or somthing
Old Oct 11, 2004 | 06:20 PM
Nishant's Avatar
Default Re: Help! (sackdz)
sounds like wrong bolt, you got a helm's?
if you do have the right bolt, try an impact wrench
Old Oct 11, 2004 | 06:22 PM
sackdz's Avatar
Default Re: Help! (Nishant)
Theres no way to get an ipmact on that without droping the motor.
That's why I think he has the wrong bolt because you cant really get a chisel on it either. Not that chisels turn bolts anyway lol..
Old Oct 11, 2004 | 06:24 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">Theres no way to get an ipmact on that without droping the motor.
That's why I think he has the wrong bolt because you cant really get a chisel on it either. Not that chisels turn bolts anyway lol..</TD></TR></TABLE>
I've seen impact ratchets that'll do 100+ ft-lb... but seriously... umm...
LEFTY LOOSEY RIGHTY TIGHTY!
-Chris
Old Oct 12, 2004 | 08:49 AM
mstewar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sackdz &raquo;</TD></TR><TR><TD CLASS="quote">Not that chisels turn bolts anyway lol..</TD></TR></TABLE>
that's what i was getting at.. lol..
Old Oct 12, 2004 | 09:09 AM
cheezthis's Avatar
You did remove the p/s belt from the p/s pulley right? Or at least, lowered that part? If not, it's very hard to get anything on that bolt. I hadve busted my hand countless times w/that bolt. I think it always hit the mount or something, ha.
Old Oct 12, 2004 | 09:36 AM
Willard's Avatar
air chisels are 'very' effective when removing stubborn crank pulley bolts..
Old Oct 12, 2004 | 09:52 AM
mikestypeRR's Avatar
Default Re: Help! (Willard)
dam didnt you think to ask and learn before you started trying to take something off... good luck
zx12ryder
22
Nov 6, 2008 06:19 AM
seeeya04
Nov 24, 2005 03:25 PM
kpringcivic
11
Oct 21, 2005 07:18 PM
kess
37
Dec 2, 2004 09:21 AM
Ignitecivic
21
Dec 23, 2003 04:03 AM
