Questions regarding a replacement motor in my hatch? Turbo ls/vtech blown
Old Oct 11, 2004 | 08:25 AM
xsellxoutx's Avatar
Default Questions regarding a replacement motor in my hatch? Turbo ls/vtec blown
Spun a bearingin #4 should i concerned about metal shavings in the turbo? The ls/vtec had a compression ratio of about 10:1, hondata, T3TO4E Garrett, 8psi on low boost, JE and Crower set up, not sleeved. If i was to replace the setup (since it is currently busted) will a stock Gsr motor suffice? Swapping the motors today regardless, just curious if i can leave it turbo for the time being?
Modified by xsellxoutx at 8:45 PM 10/11/2004
Modified by xsellxoutx at 8:47 PM 10/11/2004
Old Oct 11, 2004 | 08:44 AM
civicross's Avatar
Default Re: Questions regarding a replacement motor in my hatch? Turbo ls/vtech blown (xsellxoutx)
I wouldn't see why you would if you had an oil filter on the motor, seeing as how all of the oil has to go to that before it goes to the turbo unless you have a fitting to go straight off the oil pump.
Old Oct 11, 2004 | 09:28 AM
NC-B17A's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xsellxoutx &raquo;</TD></TR><TR><TD CLASS="quote"> The ls/vtech had a compression ratio of about 10:1 </TD></TR></TABLE>
You had a phone hooked to your LS?
Old Oct 11, 2004 | 10:01 AM
95GSRTT
Guest
Posts: n/a
Default Re: Questions regarding a replacement motor in my hatch? Turbo ls/vtech blown (NC-B17A)
lol i love when they spell it with a H
Old Oct 11, 2004 | 11:47 AM
xsellxoutx's Avatar
goddamn it!!!!!!!!!! my roommate is a fucktard who can't read....the only h under my hood is on my h22 97 hatch!
Weapon X
Aug 5, 2006 07:18 AM
96 honda hatch
Jan 5, 2005 09:46 PM
D-tuned
Oct 7, 2004 11:31 AM
Spence
Jul 15, 2004 08:41 AM
KiNG $h!t
Jun 28, 2004 12:31 PM
