All motor ls VS Turbo Ls
Well im trying to make the decision on what to do. i have a95 eg hatch that is my daily driver i want to have a quick car but have it reliable. What would you do and what are the pluses and minuses.
Thanks
Spence
Thanks
Spence
Re: All motor ls VS Turbo Ls (Spence)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spence »</TD></TR><TR><TD CLASS="quote">ok then ls vtec mang </TD></TR></TABLE>
Waste of time, and money and will probably be more of a headache than a turbo set up with less power. I would go turbo if i had an LS. Good luck with your set up.
Re: All motor ls VS Turbo Ls (hookonboost)
Ls/vtec there is a guy around here who have it. It does not pull as hard as it suppose to. It feels like a ls with just vtec sound. Something is wrong. I would just save up and slap a turbo on it.
Re: All motor ls VS Turbo Ls (lkshs123)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lkshs123 »</TD></TR><TR><TD CLASS="quote">
Waste of time, and money and will probably be more of a headache than a turbo set up with less power. I would go turbo if i had an LS. Good luck with your set up.</TD></TR></TABLE>
I would also like to know why you think ls/vtec is a waste of money and will produce less power??????
i ♥ my honda
Global Mod
Global Mod
Re: All motor ls VS Turbo Ls (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 »</TD></TR><TR><TD CLASS="quote">I would also like to know why you think ls/vtec is a waste of money and will produce less power??????</TD></TR></TABLE>
Well, IMO, the LS bottom end is NOT MADE to rev to 8k-9k rpm's so you are going to brake ****. Its praticly inevitable. Also its LOW COMPRESSION, that will need to be changed in an all motor setup. On top of that the oil sqirters are not up to task and wait, neither are the rods or pistons or oil pump or bla...bla...bla........
Get my drift.
I would say build up any 1.8 bottom end (sleves, pistons, rods) and through a vtec head on there and boost boost boost!
If you dont have the flow, just get a smaller fast spoolin turbo (t3/t4 or smaller) and a good EMS like aem or hondata and boost like 6psi on the street and 10 or 11psi at the track wit some race gas. That 10 psi will proly get you 250hp or so.
Just my .02$
Get my drift.
Just my .02$
Re: All motor ls VS Turbo Ls (si2die4)
I may have read his post wrong. I thought I read it as an Ls/vtec turbo will be more of a headache and produce less power then a ls turbo. I was going to say I put out a lot more power on my ls/vtec turbo then I did when I was straight LS.
I put down 302 @14 psi on my ls with pistons and rods
I put down 306@ 10 psi on my ls/vtec with pistons and rods.
Same turbo setup same EMS and so on.
i ♥ my honda
Global Mod
Global Mod
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 »</TD></TR><TR><TD CLASS="quote">I thought I read it as an Ls/vtec turbo will be more of a headache and produce less power then a ls turbo. </TD></TR></TABLE>
I belive you read it wrong
LS all motor
LS/VTEC all motor
LS turbo
LS/VTEC turbo
pecking order. you figure out which one you want. the easiest would be to just boost the ls. but if you have cash and know how to do the labor then an ls/vtec turbo would make more power, but how reliable it will be is up to your build and tune.
LS/VTEC all motor
LS turbo
LS/VTEC turbo
killablaze
10-07-2005 04:06 PM
