please help???
Old Oct 11, 2004 | 06:32 AM
NavyHonda95's Avatar
Default please help???
i have a '95 honda civic and and my back drivers side window wont go down, i think the window may be off tract, but im not sure. anyone got any ideas??? if so could you please help me out, and if you know tell me how to fix it.... thanks ALOT!
Old Oct 11, 2004 | 06:39 AM
civiccpedx's Avatar
Default Re: please help??? (NavyHonda05)
Well are they power windows? Also if you locat the screws on the inside door panel you should be able to pop that off and then take a look at the track. It is pretty simple you will just have to remove some plastic wrap. Also I am assuming it is a 4 door car, because if it is a 2 door then the rear windows dont go down
Old Oct 11, 2004 | 06:42 AM
Default Re: please help??? (civiccpedx)
yes they are power windows, ill try that, is it hard to do??? will it be hard to put back on???
thanks
Old Oct 11, 2004 | 06:50 AM
civiccpedx's Avatar
Well the inside panel itself isn't hard at all, I have a 2 door and in mine there were i think around 4 screws, then you just have to be rough and pop it off. It will prolly feel like it is going to break, but it won't, you have to be rough with it to get it off.
The plastic wrap on the inside it sort of hard to remove and let alone put it back on. if you don't have to remove it don't, but if you have to I don't think that not having it there will effect anything, I don't have mine on and haven't had any problems yet.
Old Oct 11, 2004 | 07:04 AM
ok, thanks alot for your help!!! ill have to do that.
thanks ALOT!
Tomas P
Apr 6, 2012 12:06 AM
eg6civic1538
Jun 1, 2007 10:19 PM
fasterthanrayswrx
Jan 26, 2007 04:36 PM
dom93hatch
Sep 17, 2002 01:33 PM
