Distributer, timing, firing order question
Old Oct 11, 2004 | 05:00 AM
Jorsher's Avatar
Default EASY distributer, timing, firing order question
Well I had a blown head gasket in my Del Sol S and since I'm broke decided to change it myself. I've never done a repair this involved before so it was pretty new to me but I learned a bit.
The problem is that my car won't start. It will try to start...but won't. I doubt the timing belt is off because I positioned it at TDC, made marks on the belt and cam sprocket, and didn't turn anything while the belt was off, so it should be on correctly. Unfortunately I didn't think about the distributor affecting the timing, and I didn't make marks on where the distributor should be.
I figure I can just slowly turn the distributer while someone cranks it until it starts...but I'd like something a little more accurate than this method, how can I correctly align the distributor?
Also, the wires that go to the plug on the IAC motor were pulled out, which wire should be closer to the firewall (I think yellow) and which should be closer to the intake manifold (I think green). If anyone could check this I'd appreciate it.
What is the correct firing order for the D15B7? The Haynes manual for the Civic & Del Sol 93-95 says 1-3-4-2, didn't specify what engine had that firing order, but when I looked at my friend's D16Z6 is 2-1-3-4 and the picture in the Helms manual of a D15 seemed to also have the 2-1-3-4 firing order but it's hard to tell.
What's a good way to flush the coolant system? Mine has oil and water in it, I just wanna get it cleaned out.
If anyone could help me out I'd really appreciate it.
Modified by Jorsher at 8:23 AM 10/11/2004
Old Oct 11, 2004 | 05:41 AM
Deemeetree's Avatar
Electrician
Facing the distributor from the passenger side of the car, it should read:
3 4
1 2
Then on the valve cover, 4-3-2-1 from distributor to camshaft sprocket.
Old Oct 11, 2004 | 05:52 AM
Jorsher's Avatar
Default Re: (Dimi)
Thanks! Well I had that right, now just to figure out the rest
Old Oct 11, 2004 | 06:56 AM
civiccpedx's Avatar
Default Re: (Jorsher)
yes the firing order is 1-4-3-2 just like the manual says. Make sure that you have the right order otherwise it will not start. My car had this problem because I was getting new wires and forgot to mark them. The manual comes in handy.
Old Oct 11, 2004 | 07:58 AM
Jorsher's Avatar
ok can anyone help with the other couple questions?
Old Oct 11, 2004 | 08:02 AM
turbo_ef9's Avatar
Default Re: (civiccpedx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx &raquo;</TD></TR><TR><TD CLASS="quote">yes the firing order is 1-4-3-2 just like the manual says. Make sure that you have the right order otherwise it will not start. My car had this problem because I was getting new wires and forgot to mark them. The manual comes in handy.</TD></TR></TABLE>
u mean 1-3-4-2
Old Oct 11, 2004 | 09:04 AM
Jorsher's Avatar
Yeah that's the firing order I have mine set at, but it just won't start. I think it may be my distributor, what is a way to get it set right?
LeegodaEG
May 6, 2013 08:33 PM
vega_ROCKS
Feb 15, 2007 10:23 PM
DrewDown
Nov 18, 2004 07:05 PM
handa
Jul 30, 2004 11:19 PM
Finest
Oct 8, 2002 07:01 AM
