Is my oil return line safe?
Old Oct 10, 2004 | 08:41 PM
BauleyCivic's Avatar
Risky Business
Default Is my oil return line safe?
Does this look like too harsh of a bend or will I be okay? T25 turbo, AN-10 Line, feed line is AN-3.
Old Oct 10, 2004 | 08:42 PM
Nikoli's Avatar
Default Re: Is my oil return line safe? (BauleyCivic)
i'd get a 45 deg. fitting off the oil pan
Old Oct 10, 2004 | 08:46 PM
adseguy's Avatar
Default Re: Is my oil return line safe? (Deckedlude)
that kink is not good.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deckedlude &raquo;</TD></TR><TR><TD CLASS="quote">i'd get a 45 deg. fitting off the oil pan</TD></TR></TABLE>
Lowe's or Homedepot...fab one up and post again!
Old Oct 10, 2004 | 09:04 PM
ATS*Mark's Avatar
OG triple OG
Default Re: Is my oil return line safe? (adseguy)
ya dood , a 45 off the pan would fix that perfectly
Old Oct 10, 2004 | 09:19 PM
Tad's Avatar
Tad
faaawk no,
that is kinked pretty badly man.
hey ur turbo now!
Old Oct 10, 2004 | 09:21 PM
Bailhatch's Avatar
Default Re: (Tad)
i'd use those parts and weld the bung on crooked. seriously, i probably would because it would fit better than a 45
Old Oct 10, 2004 | 10:07 PM
AspectIndustries's Avatar
Default Re: Is my oil return line safe? (Hella_JDM)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hella_JDM &raquo;</TD></TR><TR><TD CLASS="quote">ya dood , a 45 off the pan would fix that perfectly</TD></TR></TABLE>
Old Oct 10, 2004 | 10:40 PM
Blackack26's Avatar
Default Re: Is my oil return line safe? (synik)
I dont think a 45 would work, it would just make the angle even worse. I'd try a 90 off the pan.
Old Oct 10, 2004 | 11:28 PM
shadow103rd's Avatar
Default Re: Is my oil return line safe? (Blackack26)
I use a 90* fitting..works like a charm!!!
jon
Old Oct 11, 2004 | 04:27 AM
drvfast's Avatar
Its good enough. You could use a 90 like someone recommend so you take that little kink away.
Old Oct 11, 2004 | 05:06 AM
B18C1CYA's Avatar
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">i'd use those parts and weld the bung on crooked. seriously, i probably would because it would fit better than a 45</TD></TR></TABLE>
i agree
Old Oct 11, 2004 | 05:15 AM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Blackack26 &raquo;</TD></TR><TR><TD CLASS="quote">I dont think a 45 would work, it would just make the angle even worse. I'd try a 90 off the pan.</TD></TR></TABLE>
Thats what I figured...i'll probably try a 90 next
Old Oct 11, 2004 | 07:38 AM
Finland's Avatar
a 90 will impede flow. Go with a 45 if possible
Old Oct 11, 2004 | 07:49 AM
SOHC_MShue's Avatar
Default Re: Is my oil return line safe? (boost psycho)
yea thats what i was thinking...the 90 is probably too harsh of a bend. It may be the only option though.
Old Oct 11, 2004 | 07:51 AM
wHOAlly's Avatar
cant u rotate thet center more and use a 45 off the pan?
Old Oct 11, 2004 | 07:54 AM
EJ1 wilcox's Avatar
Default Re: Is my oil return line safe? (Sp00n'd Supra)
Yeah, definately do a 90 instead of a 45
That should fix things right up
Old Oct 11, 2004 | 07:59 AM
Risky Business
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost psycho &raquo;</TD></TR><TR><TD CLASS="quote">
a 90 will impede flow</TD></TR></TABLE>
Not as much as the kink thats in there now!
Old Oct 11, 2004 | 08:06 AM
ATS*Mark's Avatar
OG triple OG
look at the pics , how would a 45 not fix that.....youd have to shorten the line....but will fix it. i wouldnt use a 90.
Old Oct 11, 2004 | 08:17 AM
boosted-delslow's Avatar
I would just weld the fitting into the pan on an angle
Old Oct 11, 2004 | 11:06 AM
BoostedEG6's Avatar
Default Re: Is my oil return line safe? (boosted-delslow)
should use a 45 and clock the center section of the turbo towards the frount of the car alittle bit... but yeah I would get the kink out of that or bye bye turbo
Old Oct 11, 2004 | 11:45 AM
phresh_5's Avatar
Default Re: Is my oil return line safe? (BoostedEG6)
Looks like he can clock the center section just a lil bit, or else it'll be in the way of the downpipe. A 45 would definitely help. You could also try giving the steel bung on the oil pan some taps upwards. The oil pan will give a little.
Old Oct 11, 2004 | 01:32 PM
FredoSP's Avatar
Default Re: Is my oil return line safe? (phresh_5)
and don't use vice grips, it looks like your ate some of the fitting. Go to Sears and get a 1" Standard open ended wrench (or it could be 15/16")
Fred
Old Oct 11, 2004 | 01:36 PM
RyanEJ8's Avatar
Hey Bauley got a turbo! I want to see the pics, they aren't working now.
Old Oct 11, 2004 | 03:01 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
Default Re: Is my oil return line safe? (RyanCivic2000)
use a 90 not a 45.
Old Oct 11, 2004 | 08:56 PM
ILLICON3000's Avatar
take that home made crap off your car
or reweld the bung
