High revs after COI install! Help!!!
Old Oct 10, 2004 | 07:47 PM
taz104's Avatar
Default High revs after COI install! Help!!!
Hope someone can help me.
Just installed a Cold Air Intake on my wife's 99 accord...
Soon as I started it up to test, Revs shoot to about 5grand and starts pegging the rev limiter.
What did I do wrong....or what didn't I do?
I hooked the same tubes that were hooked to the OEM "intake"...noise baffle, more like it...
Old Oct 10, 2004 | 08:06 PM
RnEpmc's Avatar
Default Re: High revs after COI install! Help!!! (taz104)
your ecu hasn't compisated for the more air your getting. reset your ecu if you haven't already and let the car idel for a while. it should be fine
Old Oct 11, 2004 | 04:20 AM
Monkey Fing a Coconut's Avatar
Default Re: High revs after COI install! Help!!! (RnEpmc)
sounds like a vacuum leak, the extra air from the cai is nowhere near enough to affect the ecu, but resetting the ecu is a good idea anyways, but as for the revving 99% sure its some vacuum hose that you overlooked or an open nipple on the IM
murphydennis17
Feb 26, 2013 08:37 AM
hondacrxflyer
May 26, 2004 09:27 AM
shivic
May 15, 2002 02:32 PM
cardoobie
Mar 9, 2002 05:30 PM
