spark plug??? help please
Old Oct 10, 2004 | 07:42 PM
teh leet civic's Avatar
Default spark plug??? help please
ok, heres my story, i bought a b16a2'd civic, there was black crap, coming out of my exhaust when i started my car, someone told me i'm probly running rich, and i should try replacing my plugs, i then pulled my plugs, they were denso iridiums, one was all crapped up, and the gap was HUGE, the gap was different from all the others, anyway, i replaced the plugs with stock plugs, NOW, when i get to higher rpms ( 6-8k) its just not the same power as before, could my car be running lean since i changed the plugs, and maybe it was tuned with the densos? im stumped, should i get some denso's and put them in??? also, what should i gap the plugs at, any suggestions?
this might be confusing to understand, please help, ask me questions if you dont understand
thanks
Old Oct 11, 2004 | 05:39 AM
pr3B20pwr's Avatar
Yes try back the Denso(new one) keeping the same gap on both stock and Denso to eliminate the spark plug issue.
Old Oct 11, 2004 | 07:52 AM
Default Re: (pr3B20pwr)
what is the stock gap on a b16a2, i dont have an owners manual, and i dont understand spark plugs
Old Oct 11, 2004 | 08:30 AM
Two_K Si's Avatar
Default Re: (teh leet civic)
You should use NGK PFR6L-13 or DENSO PK20PR-L13 in a b16. They are platinum plugs, and the gap is 1.3mm or .051 in. Platinum plugs come pre gaped out of the box, but it is always good to recheck the gap.
Old Oct 11, 2004 | 12:54 PM
Default Re: (Two_K Si)
OOOOOO, ok, i think i figured it out anyway. my oil was like MAD thin, didnt even stick to dip stick, i ran a whole bottle of sea foam thru her the other day, and i have drivin like 300 miles since, i added some oil (almost 3 quarts to be exact...) i didnt think the seafoam would effect it that much, does this sound normal? im changing my oil tonite, completely, would that make it pulll less at high rpms? if it was so thin, and non existant
i suck
Old Oct 11, 2004 | 12:56 PM
two k si, thanks for the info, although my local autozone doesnt carry ngk's and they didnt have the densos in stock, ill have to go some where else, or order them, right now im runnin stockys
Old Oct 11, 2004 | 04:06 PM
up dis, i need some input. wrd
Old Oct 12, 2004 | 08:47 PM
BAD OIL
thanks for teh help guyz
jdmitr01
Oct 8, 2004 09:57 PM
Aeka GSR
Dec 5, 2003 10:14 AM
ALLMOTOR18
Sep 10, 2002 03:05 PM
Casey
Mar 19, 2002 07:00 PM
mattmw88
Feb 22, 2002 07:54 AM
