help with fans
Old Oct 10, 2004 | 07:02 PM
ogichida's Avatar
Default help with fans
I just bought a 98 GSR and the fans are not working. If anyone has experience with this please email me at applepieyumyum@aol.com.
Old Oct 10, 2004 | 08:21 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: help with fans (applepieyumyum)
Do they never come on at all, even if you turn the A/C on? Neither one comes on? That's probably a fan relay problem. If they don't come on to cool the engine, but do come on w/ A/C, then it's probably a bad coolant temp switch (thermostat housing).
Old Oct 10, 2004 | 08:45 PM
Oleg's Avatar
First thing to do is to chek the fuses, if they are good, then chek the relays(swich places with the good one) and see if it works. than disconnect the connector from the fans and try to jump them from the battery with a pair of jumper cables. (if fan won't come on than it means that they are bad ) another good thing to do is check the ground ...... Temp sensor usually dont go bad , but it won't hurt if you chek them too.
Neo218
Apr 5, 2010 07:15 PM
mcclungd2000
Oct 22, 2007 03:29 PM
bjrobinson72
Nov 23, 2006 04:26 PM
dog70
Jun 9, 2006 04:27 AM
yangtech
Oct 6, 2005 06:44 PM
