mad wheel hop after spring and shock install
Old Oct 10, 2004 | 06:46 PM
Elemental's Avatar
Default mad wheel hop after spring and shock install
i just installed my koni yellows and h&r race springs. i have crazy wheel hop in first gear. what happened? what do i need to do to fix this?
kind of obscure question, but yeah.
i forgot to screw in the shock collar bolt (the top one that keeps the shock collar clamped, not the bottom long one), so would that affect anything?
on a side note, how long does it take these springs to settle? i still have wheel gap dammit!
Old Oct 10, 2004 | 07:08 PM
eda6's Avatar
Default Re: mad wheel hop after spring and shock install (Kyoushu)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyoushu &raquo;</TD></TR><TR><TD CLASS="quote">i forgot to screw in the shock collar bolt (the top one that keeps the shock collar clamped, not the bottom long one), so would that affect anything?</TD></TR></TABLE>
Fix it right and see what happens
Old Oct 10, 2004 | 07:26 PM
Elemental's Avatar
ahaha. i cant find the bolt. im glad it is a 14mm, because i have plenty of those lying around and that nut from the stock shock will work just fine.
Old Oct 10, 2004 | 07:38 PM
Bailhatch's Avatar
Default Re: (Kyoushu)
huh, it's a 10mm bolt (10 x 1.25 i believe). it does not use a nut, the other side of the fork is threaded. I can't believe you drove it with no bolts!
Old Oct 11, 2004 | 04:40 AM
Elemental's Avatar
nvm i did. ha.
Old Oct 11, 2004 | 04:49 AM
Elemental's Avatar
im just ocd.
stock99si
Jul 13, 2007 11:12 AM
2LoW4FaThOeS
Honda Civic (2001 - 2005)
Apr 3, 2006 09:55 PM
psdvette
Sep 21, 2003 12:53 AM
chris215chris
Aug 17, 2003 08:18 PM
rjl2001
Jul 16, 2002 01:17 PM
