camber problems with integra rear brakes
i just got the rear brake swap done and the wheels do this / \ when you look at the car from behind. i swapped out the small control arm at the front for the crx one so there is no toe in. do you have to use the crx upper control arm as well? the upper ones looked like they are identical on both integra and crx. there were no camber problems with the stock suspension. leave some bs.... thanks
well the drivers side upper control arm is crx and the assenger side is integra. they are off by the same ammount, maybe all thses swaps sit retarted. pics? links...... maybe im paraniod, who knows
so i take it that the lower control arms off of an integra are a little too long, i would use the old dx ones but there are no bolt holes for a sway bar so i will just wait untill i get ahold of some off of a crx si. its not like i have to drive it anyways
90civicstdgold
10
Jan 19, 2010 07:05 PM
steronz
Sep 30, 2004 09:11 AM
krshultz
30
Nov 7, 2001 04:37 PM
