how many of u turbo-d's run stock fuel pump w/dsm 450s
Old Oct 10, 2004 | 05:46 PM
honda9369's Avatar
Default how many of u turbo-d's run stock fuel pump w/dsm 450s
im curious cuz im running the walbro 255lph hp and i think its the source of my problem. i think i might get a prelude pump and try that out.
Old Oct 10, 2004 | 06:12 PM
honda9369's Avatar
Default Re: how many of u turbo-d's run stock fuel pump w/dsm 450s (honda9369)
anyone got a cheap prelude pump 4 me
Old Oct 10, 2004 | 06:13 PM
93turbo16's Avatar
I'm running the 450s, no problem at like 42 psi or so, on uberdata. Runs perfect.
Old Oct 10, 2004 | 06:16 PM
USDM 4G VTEC's Avatar
sotkc fuel pump here
450cc DSM
the hack (for now)
under boost i keep 50psi on a bigass Edelbrock 7/8 ID fuel rail
Old Oct 10, 2004 | 06:21 PM
honda9369's Avatar
Default Re: (93turbo16)
yea i used a b+m fpr and drilled a hole in the stock pfr and managed to get it down to 39 with the vac line on. ok so maybe its the injectors. what ohms should the 450 be at.
Old Oct 10, 2004 | 06:26 PM
93turbo16's Avatar
Hm not sure about that. What is your car doing that makes you think something is wrong with the injectors?
Old Oct 10, 2004 | 06:38 PM
honda9369's Avatar
black plugs in a short period of time. runs so rich i cant drive it.
Old Oct 10, 2004 | 07:55 PM
beerbongskickass's Avatar
Default Re: (honda9369)
I have been running the stock pump for 7 months. I have a walbro 255 I am going to start running though (I did for a day and it was fine). Had to use my stock pump again though because I broke the walbro so I couldn't get a filter on it, once that is fixed the walbro is going back in.
Old Oct 10, 2004 | 08:30 PM
honda9369's Avatar
Default Re: (beerbongskickass)
yea my filter didnt fit on right. i hope it didnt fall off. it would be a bitch to fish that out. when i took out the stock pump the filter fell off and had a **** *** time tryin to get it out. cut my hand and had blood all over the place,lol
Old Oct 10, 2004 | 10:25 PM
honda9369's Avatar
ok so has anyone had problem with the walbro high pressure pump or should i say who is running the hp pump?
Old Oct 10, 2004 | 10:55 PM
racinskittle's Avatar
I do, have been for almost a year now
Old Oct 11, 2004 | 05:01 AM
93turbo16's Avatar
Your problem sounds more like a stuck injector problem or something of that sort. I varried fuel pressure from 35 to 42 and it still idled fine and didn't turn the plugs to black. Thats on the stock pump of course.
Old Oct 11, 2004 | 07:41 AM
tgreaves's Avatar
Default Re:
Im running a little over 10psi on a stock fuel pump with 450cc dsm's..
Old Oct 11, 2004 | 07:55 AM
SOHC_MShue's Avatar
Default Re: Re: (tgreaves)
damn why did I have so much problems with running the stock pump and 450's. At 8-10psi I was detonating or misfiring pretty bad once in vtec. My walbro pump solved the problem.
Old Oct 11, 2004 | 07:58 AM
tgreaves's Avatar
Default Re: Re: (SOHC_MShue)
Might not have had your tuning correct.. If you kept the same fpr then with the walbro your fuel pressure went up and fixed your air/fuel ratio.. Just a thought..
Old Oct 11, 2004 | 09:26 AM
SOHC_MShue's Avatar
well i didn't get the hp walbro...just the 255lph. I'm not sure if that would raise my fuel pressure or not. I tried fooling around with my maps a number of times to fix it before I got my fuel pump. I was basically maxing out my 450's and still it was doing it. I even tried retarding my timing all over the place and nothing worked until I did that. Maybe my stock fuel pump was crapping out?
Old Oct 11, 2004 | 09:36 AM
fsp31's Avatar
Has there ever been a consensus on whether all "stock" sohc fuel pumps are created equal?
The stock pump from my 98' D16Y7 was certainly NOT up to the task (with only 60,000 miles at the time). The engine was "converted" to a y8 via a head, tranny, and ecu swap prior to the turbo. No matter what the tune (on dsm 450cc injectors), it would begin to lean out at about 4000 rpm's, then get pretty dangerous by 5500. Once again, the Walbro 255 lph solved all that. I went with the high pressure version. It's an easy install, fairly cheap, and I like the peace of mind knowing the pump can easily provide all the fuel my injectors might need.
Old Oct 11, 2004 | 02:56 PM
honda9369's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgreaves &raquo;</TD></TR><TR><TD CLASS="quote">Im running a little over 10psi on a stock fuel pump with 450cc dsm's..</TD></TR></TABLE> 10 psi. am i reading that right? my car is not tuned yet. im tryin to get it running so i can take it to a tuner.
tron-R
Jul 13, 2007 04:31 PM
KevronsEG
Jan 7, 2003 08:01 AM
rjardy
Oct 14, 2002 08:15 AM
revhrdls
Aug 31, 2001 08:12 AM
