need help with my b16sir2 swap into an 93eg
Old Dec 15, 2001 | 06:52 PM
BlueR's Avatar
Default need help with my b16sir2 swap into an 93eg
i'm at a crossroads regarding the ecu
what is the best way to go?
what ecu will work with my swap?
thanx
Old Dec 15, 2001 | 10:10 PM
rainforest's Avatar
Default Re: need help with my b16sir2 swap into an 93eg (BlueR)
gsr gsr ecu
b16a p30 ecu. there you go. nacka.
Old Dec 16, 2001 | 07:19 AM
fowler!'s Avatar
skunk2 p28
Old Dec 17, 2001 | 07:53 AM
BlueR's Avatar
Default Re: need help with my b16sir2 swap into an 93eg (rainforest)
gsr gsr ecu
does anybody know where i can purchase the above items?
also can i used the ecu from the current civic si's?
how much for the skunk p28?
thanx
[Modified by BlueR, 11:54 AM 12/17/2001]
Old Dec 17, 2001 | 08:29 AM
fowler!'s Avatar
The obd 1 P30 and P72 will be kinda expensive. Anywhere from 250-350. You can usually find one on the partstrader.
A skunk2 p28 is basically a chipped version of the ecu that you are currently running in your 93 Si. Those cost anywhere from 100-150 to get chipped and will outperform a stock ecu. That is what I'd do in your case. Any import shop can refer you to someone that will be able to chip an ecu.
They have a variety of different programs that you can choose from. I say skunk2 because I hear it's very nice. Basically, all the programs are variations on how much fuel and other things you get.
hth.
Old Dec 17, 2001 | 08:32 AM
BlueR's Avatar
Default Re: need help with my b16sir2 swap into an 93eg (fowler yo!)
i think i'm gonna go the skunk route unless i can get one of the obd1 ecus locally
can you recommend a reputable place, no partstrader
Old Dec 17, 2001 | 08:46 AM
fowler!'s Avatar
unfortunately, partstrader is the best bet to find one. Try the recycler or ebay or something. If you end up buying from a store...they're gonna charge you up the a-hole
Old Dec 17, 2001 | 08:50 AM
BlueR's Avatar
hopefully, someone from here reads my post and hooks me up
thanx for you quick response, fowler
Old Dec 17, 2001 | 08:54 AM
fowler!'s Avatar
just post a "wtb" ad in Honda-tech classifieds...there is always someone that will respond. Just be picky who you buy from.
no sweat
Old Dec 17, 2001 | 06:32 PM
Kamin's Avatar
yea someone has to be selling one on ebay.
if not ebay the people in our classifides forum are good
id sell you mine but i need it for my swap
Old Dec 18, 2001 | 08:15 AM
chi1874436's Avatar
Default Re: need help with my b16sir2 swap into an 93eg (KAMiN)
What kind of 93 eg do you have? If you already have Vtec, then you have the p28 and all you have to do is get it reprogrammed. If not then i recommend the p28 or p72 ecu because their both reprogrammable ecu's. You may also want to check jdmhondaparts.com.
Old Dec 18, 2001 | 05:03 PM
B_CRUZ!'s Avatar
Default Re: need help with my b16sir2 swap into an 93eg (chi1874436)
yeah KATMAN can reprogram VX, CX, DX and automatic P28's to DOHC VTEC spec. he can make it MUGEN spec or what ever program you want. i got my P72 reprogrammed by him and i have the option of making it stock just by removing the ecu cover and removing a jumper pin.
jhp.com
[Modified by eg6_inspired, 6:03 PM 12/18/2001]
Old Dec 19, 2001 | 11:04 AM
stevecockrill's Avatar
Hondata, Hondata, Hondata. Its all you need to know. Stage 2 or above will do you fine on your P28 (I'm assuming that's what you have). Perfect for my swap (99 Civic B16A2 into 93 del Sol D16Z6).
Steve
Old Dec 19, 2001 | 11:52 AM
Katman's Avatar
Default Re: need help with my b16sir2 swap into an 93eg (eg6_inspired)
jhp.com
err actually I can't do VX ECU's yet -- he he
there's 2 different types of VX ECU's and I've only come across on type which isn't chipper friendly. The other type is more along the lines of a P28 ECU, which IS chipper friendly...
How's your ECU holdin up sir?
Blue R --
if you need reprogramming assistance, please let me know
I provide services for 88-95 ECU's only. I can't do OBD2 ECU's.
[Modified by Katman, 12:52 PM 12/19/2001]
elmejor
Aug 24, 2008 05:39 AM
lambo95
Jan 15, 2007 06:44 PM
Gonzo
Jul 19, 2005 01:31 PM
kenji
Jan 28, 2002 06:41 PM
