Has anyone reflared brake hardlines?
This is just my personal experience, but I couldn't get a single one of my flares to work with an Autozone flaring tool...they all would leak. This was with the lines off of the car, too...
Good luck to you, though, and I would test it on another brake line before you do your car
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">I'm going to try a ghetto fab method of connectiong to hard lines with a fuel hose.
okay but why? what is the point/benefit to what you are doing?
</TD></TR></TABLE>okay but why? what is the point/benefit to what you are doing?
I already removed the stock prop valve but ran into a problem. The thread on one of the fittings is not clean anymore and won't go into the prop valve all the way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pdiggitydogg »</TD></TR><TR><TD CLASS="quote">if you double-flare they shouldnt leak at all
Did you use the right size, hawk?</TD></TR></TABLE>
I double flared them with the right size, but I couldn't get the damn needle-punch deal on the tool to stay straight, so each flare was a little angled to one side. After I beat several holes in the concrete with my head, I gave up and bought already flared lines...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY »</TD></TR><TR><TD CLASS="quote">I already removed the stock prop valve but ran into a problem. The thread on one of the fittings is not clean anymore and won't go into the prop valve all the way. </TD></TR></TABLE>
You should be able to find one at the junkyard easily and cheaply...
