larger throttle body + modified intake mani?
Old Oct 10, 2004 | 02:59 PM
Fink2iCe's Avatar
Default larger throttle body + modified intake mani?
I'm thinking of getting the skunk2 b18c5 intake mani as i have a b18c5 cylinder head on my 1994 Si. If im gonna make that change im guessing I will need a 62mm throttle body?
What if I want a 65mm TB or larger, do I need to bore the intake mani slightly to match the size of the TB bore? If not, whats the point of having a larger TB (bigger than 62mm) with a b18c5 intake mani??
Old Oct 10, 2004 | 04:31 PM
Fink2iCe's Avatar
Default Re: larger throttle body + modified intake mani? (Fink2iCe)
bump - anyone??
Old Oct 10, 2004 | 04:44 PM
shutupitsANDREW's Avatar
65mm is direct bolt on. i believe 70mm you would need to bore out the mani.
bigger also gives out the sick *** wide open throttle growl sound.
Old Oct 10, 2004 | 05:55 PM
B18cya00's Avatar
Default Re: larger throttle body + modified intake mani? (djfuzziebear)
Get 65mm i have the skunk2 manifold and the jg 65mm throttle body on mine nad they are both very nice.
Old Oct 10, 2004 | 06:21 PM
txracer's Avatar
Default Re: larger throttle body + modified intake mani? (B18cya00)
what about for a 91 ls with everything stock cept for a cai,cat back, and strut bars
, whats the max tb size i can go to before i have to do any machine work?
Old Oct 10, 2004 | 07:27 PM
LSvtec03's Avatar
Default Re: larger throttle body + modified intake mani? (txracer)
you have a type r head, and you want a skunk2 mani? what kind do you have on there now? i hope you realize the skunk2 is a replica of the type r, with a few minor differences...
Old Oct 11, 2004 | 08:53 AM
Fink2iCe's Avatar
Default Re: larger throttle body + modified intake mani? (LSvtec03)
Yea I have a type r head but I have the non-type r manifold, i.e. dual plenum.
Old Oct 11, 2004 | 09:19 AM
Sack Master's Avatar
So are you saying you have a gsr manifold that is all hacked to **** so that it will fit on a pr3 head? Who the hell would ever do that? EVER? Thats like sleaving a 350 chevy to a 3.736 bore and making a 305 out of it. Kinda pointless.
Old Oct 11, 2004 | 09:23 AM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Fink2iCe &raquo;</TD></TR><TR><TD CLASS="quote">Yea I have a type r head but I have the non-type r manifold, i.e. dual plenum.</TD></TR></TABLE>
are you sure you have a b18c5 head and not a b18c1?
Old Oct 11, 2004 | 10:10 AM
Fink2iCe's Avatar
Can't be 100% sure, the car was sold to me like this. The car revs to just over 8000rpm nicely. My car is not a GSR, it is a JDM Si VTEC and has the B18C block. I the fitting of the intake mani looks clean, no hacking or crackin
Old Oct 11, 2004 | 10:34 AM
Does the head say p72 on it??
Old Oct 11, 2004 | 11:17 AM
Fink2iCe's Avatar
Default Re: larger throttle body + modified intake mani? (Sack Master)
where should I look for this??
Old Oct 11, 2004 | 06:53 PM
LSvtec03's Avatar
on the front of the head, above the exhaust manifold. it will say P72 or PR3 or some such.
95egianp
Mar 18, 2013 04:46 PM
cranker
Jul 22, 2010 11:39 PM
95bkeg
May 13, 2006 05:39 PM
dave24
Jan 5, 2006 05:13 PM
Big Josh
Sep 10, 2004 12:28 PM
