Setting Idle Speed on '92 Accord
Old Oct 10, 2004 | 11:43 AM
tulsa442's Avatar
Default Setting Idle Speed on '92 Accord
My 92 accord is idling at about 450, need to set it to around 700. My Haynes manual says to: with the engine running, first disconnect the IAC electical plug, but as soon as I do, the car dies. I tried adjusting it without unplugging it first, and it doesn't change.
Can anyone help? Thanks!
Old Oct 10, 2004 | 06:07 PM
KatyHonda's Avatar
Default Re: Setting Idle Speed on '92 Accord (tulsa442)
First clean the throttle plate and throttle body bore carefully w/ throttle body cleaner and an old toothbrush. Soft brush is necessary to avoid scratching the throttle body bore.
Next clean the Electronic Air Control Valve (EACV) and make sure it's working.
Then you should find the idle speed greatly improved and may not need to adjust the air bypass screw as per the Haynes manual.
good luck
Old Oct 10, 2004 | 06:16 PM
tulsa442's Avatar
Default Re: Setting Idle Speed on '92 Accord (KatyHonda)
What exactly is the throtle body bore?
Old Oct 11, 2004 | 12:28 AM
Trumpster's Avatar
The throttle body bore (to the best of my knowledge) is the "hole" that the throttle body plate goes in (that piece of metal that turns to allow air to flow into the throttle body). Didn't mean to sound condescending when I said that if I did. But that's what it is, again, to the best of my knowledge, someone please post up on this to confirm or give this guy the proper answer. I hope I helped and thanks to anyone who follows up on this.
Old Oct 11, 2004 | 03:14 AM
KatyHonda's Avatar
Default Re: Setting Idle Speed on '92 Accord (Assassin247)
Yes, bore is center opening as in "bore of rife".
good luck
Old Oct 11, 2004 | 01:41 PM
tulsa442's Avatar
Thanks guys, I'll let you know if this solves the problem.
Wrench271
Feb 12, 2017 04:06 PM
Orie Bethel
Mar 7, 2016 10:02 AM
ekhatch66
Engine Management and Tuning
Aug 24, 2009 12:04 PM
LiL accORd RideR
Oct 9, 2004 10:48 AM
luc_cairo
May 2, 2002 06:33 PM
