Jun Type 3 and VTEC
Old Oct 10, 2004 | 10:50 AM
squale's Avatar
Default Jun Type 3 and VTEC
I have a civic EG with a B18C6 engine
I mounted camshaft JUN Type 3 with Piston PCT "B16B"
but i have a problem when the VTEC engage
i like to know your opinion about my problem
injector too small ? cams ? ...
Dyno
ps: Sorry for my English
Old Oct 10, 2004 | 11:42 AM
asubennett's Avatar
Default Re: Jun Type 3 and VTEC (squale)
What is the problem with it?
Did you check piston to valve clearence?
Old Oct 10, 2004 | 11:58 AM
murtnabila's Avatar
Default Re: Jun Type 3 and VTEC (asubennett)
I think the problem is a huge drop in power.
Old Oct 10, 2004 | 12:24 PM
squale's Avatar
yes
the block is Bored ( 81.25 ) and cheked
Old Oct 10, 2004 | 12:29 PM
squale's Avatar
could that be a fuel lack?
wouldn't a APEXI Vafc 2 with Injector 310cc that go?
Old Oct 10, 2004 | 02:40 PM
typeCSI's Avatar
theres no fuel for the upgraded cams, it needs more fuel. you need to tune your ecu. you could go with a vafc.
is your motor stock? to use the full potential of the cams, you would need other upgrades. ie: bigger TB, header, valvetrain, etc.
is that your air/fuel ratio there at the bottom?
Old Oct 10, 2004 | 02:45 PM
pr3B20pwr's Avatar
Ton VTEC engage trop tot.Avec ton set-up le VTEC devrait s'engager au alentour de 6500rpm. Si il engage trop bas ton moteur ne pompe pas asser d'air pour le gros lobe de tes cams, donc tu perd des hp et sa remonte ensuite.Ton max hp devrait etre vers 8300/8500 avec des JUN 3(je roule des JUN 3 depuis 3ans)
Old Oct 10, 2004 | 03:54 PM
PyroProblem's Avatar
Default Re: (pr3B20pwr)
french?
No comprende senior,habla ingles?
Old Oct 10, 2004 | 04:16 PM
GeeReg's Avatar
Default Re: (PyroProblem)
Your VTEC engages too tot.Avec your set-up the VTEC should engage in the surrounding of 6500rpm. If it engages your engine too low does not pump asser air for the large lobe of your camwoods, therefore you HP lose and its ensuite.Ton max HP goes up should be towards 8300/8500 with JUN 3(je rolls of the JUN 3 since áns)
lol
Basically the Jun III's need pretty high VTEC engagement and it's probably too low.
Old Oct 10, 2004 | 04:44 PM
Padawan's Avatar
Darth ModerVader
That graph is pretty difficult to decipher, but it looks like you might have a major fuel problem at the point where the big cams come on. What sort of provisions do you have for tuning, and how much tuning was done? As others have said, you'll also most likely want to move the VTEC engagement point up quite a bit (though it's not easy to tell where it's currently set with that graph).
Old Oct 11, 2004 | 12:00 AM
squale's Avatar
je suis Belge
je comprends tres bien ce que tu dit
desoler pour le temp de reponse mais ici il est 10h30 AM
ps: tu parle tres bien francais
merci
Modified by squale at 10:29 AM 10/11/2004
Old Oct 11, 2004 | 12:27 AM
squale's Avatar
I have H/I/E
Ecu P30 ( Rev 9000 )
Spring & Retnaire JUN
Head Polished
I have a throttle body EG6 (60mm)
Injector STOCK 240cc
Fuel Rail STOCK
FRP STOCK
Old Oct 12, 2004 | 08:31 AM
squale's Avatar
Up
Old Oct 12, 2004 | 08:45 AM
mmuller's Avatar
Mad Scientist
Default Re: (squale)
tune it, your injectors are way small.
your running a stock ecu? OUCh can you say boom
you really need to tune for that very high 12's compression
kikoy
13
Apr 13, 2006 09:01 AM
Alchemic_rb
Jan 9, 2005 08:41 PM
12secLSvtec
11
May 20, 2004 12:04 PM
teg1.6
Sep 13, 2001 06:27 PM
Leo95SE
Aug 10, 2001 01:26 PM
