My harness wont connect to my injectors
I have a 2001 GsR head, but the 2001 ITR harness of mine wont connect to the injectors, they dont seem to look like they are the right plugs. Anyone know if I need ITR injectors? Please help.
the only differences I know between injector plugs and the harnesses was that the harness plugs were changed in 96 when they switched over to OBD2. The OBD1 plugs had that stupid wire clip around it which is always a PITA, while the OBD2 harness had normal plugs that you could just squeeze the tab to unlock them. Do your plugs have the wire clip thingy around the plug?
No, it's the squeeze tabs, but the injectors seem not to fit.....Is there a trick to getting them plugged in? Maybe I have older injectors? What do the older ones look like? Are there any differences between the obd1 injector and obd2?
Ek9Kiddo
Sep 5, 2010 12:04 PM
SIR2Hatch
Feb 27, 2010 11:35 PM
h22a4sol
10
Dec 12, 2009 06:31 AM
