vafc2 BIG BUG
Old Oct 10, 2004 | 09:35 AM
dc4drewH's Avatar
Default vafc2 BIG BUG
fri. night i had my car dyno tuned at the local shop. We played with the vafc for about an hour and we found out the my best X-over point was 5200 and now I am putting down 160,118 w/ b18c1-sk man, ctr cams, int, exhs,. And that was the good news. When it came down to changing the fuel incraments around it just seems like NOTHING happened... from what i've seen before the older version seemed pretty sensitive to the adjustment of incrament through the wide band.. which would budge from high 14'a across all night. I already checked the wiring diagram 3thrice, so i was wondering if there might be a recall or just somthing im not getting to...
Old Oct 10, 2004 | 03:06 PM
dc4drewH's Avatar
Default Re: vafc2 BIG BUG (dc4drewH)
bump
Old Oct 11, 2004 | 12:53 PM
dc4drewH's Avatar
help a TUNA!
Old Oct 12, 2004 | 12:54 PM
dc4drewH's Avatar
to top!
Old Oct 12, 2004 | 05:12 PM
dc4drewH's Avatar
2 the top
Old Oct 12, 2004 | 05:37 PM
dc4drewH's Avatar
tippy top
Old Oct 12, 2004 | 05:52 PM
IN VTEC's Avatar
Were you trying to add fuel?
Old Oct 12, 2004 | 06:01 PM
dLo GSR-stolen-now-WRX's Avatar
From: kyoto sangyo daigaku, kyoto, japan, sometimes bay area CA
i really doubt it's the unit's fault.
Old Oct 12, 2004 | 07:29 PM
dc4drewH's Avatar
Default Re: vafc2 BIG BUG (dLo GS-RaArRrRrR... aRRR!)
20+ on wide and narrow throttle and no changes....still clueless
Old Oct 12, 2004 | 07:54 PM
IN VTEC's Avatar
What I believe is happening is that pressure columns above atmospheric don't have significant amounts of additional inj pulsewidth, so no matter how much extra MAP voltage you add, it won't enrichen it any further.
Use an OBD-2 scanner with real-time sensor reading to check inj pulsewidth as a function of VAFC positive correction while making full throttle passes on the dyno. That will either confirm or disprove my theory.
PM me if you want, since I'm leaving out a huge hole in the explanation that you might or might not be familiar with.
dc4drewH
Oct 14, 2004 05:14 PM
92b16vx
Mar 22, 2004 01:36 PM
Mark
Mar 6, 2004 11:05 AM
VTECivic4
Mar 5, 2003 07:33 PM
burninCRX
Feb 10, 2003 08:31 AM
