pls help code 10
Old Oct 9, 2004 | 09:14 PM
jpangeles's Avatar
Default pls help code 10
yesturday i just did my ls/vtec it's working fine but now when i started this morning it wont start...it's cranking but it seems the their is no spark....i check all the spark plugs and the plugs is really dirty and filled in smoke....i check the ecu the code is throwing the code 10....pls anyone can help me...i need to make my car running before the crxpo 2004 meets..
Old Oct 9, 2004 | 09:18 PM
DieMaster's Avatar
Needs to be About 20% Cooler
Default Re: pls help code 10 (jpangeles)
here's the codes:
http://www.hondata.com/techecucodes.html
10 in intake air temp and it dosent prevent the car from starting it's somthing else
Old Oct 9, 2004 | 10:28 PM
drussell4801's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jpangeles &raquo;</TD></TR><TR><TD CLASS="quote">but it seems the their is no spark....</TD></TR></TABLE>
is there spark or not?
Old Oct 10, 2004 | 08:32 AM
jpangeles's Avatar
Default Re: pls help code 10 (drussell4801)
yeah their is spark
Old Oct 10, 2004 | 08:03 PM
three things you need for the car to run: Spark, compression, fuel.
Figure out which one you aren't getting.
Old Oct 13, 2004 | 06:57 PM
89hbcivicguy's Avatar
code 10 can prevent the car from not starting....i just went through the same this.........
the Intake Air Temperature controls how much air/fuel is getting pushed through then intake!
S2k_girl
Sep 27, 2007 04:15 PM
building boost
Mar 2, 2007 06:48 PM
Babybluegsr92
Jan 24, 2002 05:31 AM
evo
Dec 8, 2001 12:01 PM
