JDM B16A into 92 Civic Hatch, Distributor wont work what do I use
Old Oct 9, 2004 | 04:37 PM
ImThatGuy's Avatar
Default JDM B16A into 92 Civic Hatch, Distributor wont work what do I use
I need some help we have a JDM B16A from a 88 - 91 civic an we are putting it in a 92 civic cx, an we need to know what distributor to use for the OBD1 we already tried a b16a3 from a del sol an it won't fit, what can we do to get this problem solved
Old Oct 9, 2004 | 04:39 PM
Filliam H. Muffman's Avatar
Default Re: JDM B16A into 92 Civic Hatch, Distributor wont work what do I use (ImThatGuy)
get a dizzy from a 88-91 civic with a b16a.
logic owns you...
Old Oct 9, 2004 | 04:50 PM
civic2slo's Avatar
if I'm correct a b16a3 is 96-97 del sol and is obd 2 not obd 1.
you can use a jdm 92-95 b16a/b,b18c, usdm 94-95 b16a, 94-95 gsr distributor.
but if you are in a bind/budget (ghetto) you can use a rs/ls distributor by cutting one leg of the distributor off. or if you have the distributor from an obd 2 you can re-wire it or just trade it for a obd 1.
Old Dec 3, 2004 | 03:36 PM
rickinthescv's Avatar
I used a TD22U, look it up from Distributor King to make sure the holes line up.
JDM B16 with a cable transmission (circa 88-91)
Old Dec 3, 2004 | 04:17 PM
nub.96ek's Avatar
I know the dizzi off of a b17a [92-93 gsr] works
Old Dec 3, 2004 | 04:59 PM
mwieczorek43's Avatar
Default Re: JDM B16A into 92 Civic Hatch, Distributor wont work what do I use (NUB-96EK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic2slo &raquo;</TD></TR><TR><TD CLASS="quote">But if you are in a bind/budget (ghetto) you can use a rs/ls distributor by cutting one leg of the distributor off. </TD></TR></TABLE>
yup
Old Dec 3, 2004 | 05:05 PM
MassScene's Avatar
If its a problem of the plugs not fitting go to a junkyard and cut off a the plug from the same year as your harness. All the colors are the same from obd1 and obd 2 so imagine the colors are still the same.
roadawg
34
Sep 2, 2003 08:44 PM
TheHatchHog
11
May 11, 2003 01:20 PM
TheKid
Jun 20, 2002 11:23 PM
VTECVillain
Dec 21, 2001 09:23 AM
Jared
Jul 12, 2001 06:00 PM
