The Honda brake pedal squeak, where do I put the lube? :)
Old Oct 9, 2004 | 03:42 PM
Erod's Avatar
Default The Honda brake pedal squeak, where do I put the lube? :)
(Good title to get responses I figured, lol)
Driving my Civic today I thought, "geeze that little squeak from the pedal when you let off the brakes if annoying" which was followed by "why the hell havent I posted on HT to see how to fix it?"
So I am. (I searched first just now)
I swear my 90' 4-door did it just the same. Where does it come from? Inside the passenger cabin? Outside? (Sounds like outside) Help! Thanks!
Old Oct 9, 2004 | 03:45 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: The Honda brake pedal squeak, where do I put the lube? :) (Erod)
Just like a door your brake pedal also has a hinge or pivot point, that's where you need to lube.
Old Oct 9, 2004 | 04:00 PM
EX-T's Avatar
Default Re: The Honda brake pedal squeak, where do I put the lube? :) (00Red_SiR)
where? is that pivot/hinge...
Old Oct 9, 2004 | 05:13 PM
00Red_SiR's Avatar
All Motor Mentor
Default Re: The Honda brake pedal squeak, where do I put the lube? :) (DSeriesBKilla)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSeriesBKilla &raquo;</TD></TR><TR><TD CLASS="quote">where? is that pivot/hinge...</TD></TR></TABLE>
Try looking under the dash where the pedals are mounted...
charlee
Feb 4, 2007 09:09 PM
bunburyd16y
Nov 26, 2006 01:54 PM
jEE
10
Apr 11, 2006 05:56 PM
JimmyAtlantis
11
Mar 3, 2004 09:46 AM
slooogsr
Aug 8, 2003 10:18 AM
