b-series timing belt question?
Old Oct 9, 2004 | 12:43 PM
eg_type_r93's Avatar
Default b-series timing belt question?
i was wondering if anyone has a pic from a helms manual on where the timing marks line up specifically the crank gear (gear behind the crank pulley)
- does the line on the crank gear line up with the one on the oil pump?
- or should i just line up the crank pully timing mark straight up?
- or just make sure cylinder #1 is at tdc and forget the marks?
- cams both positioned stright up
Old Oct 9, 2004 | 01:56 PM
.RJ's Avatar
.RJ
Default Re: b-series timing belt question? (eg_type_r93)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg_type_r93 &raquo;</TD></TR><TR><TD CLASS="quote">- does the line on the crank gear line up with the one on the oil pump?
Yes.
This has to be lined up, along with the cam gears. Dont use the crank pulley.
Old Oct 9, 2004 | 02:01 PM
JDM CTR '00's Avatar
Default Re: b-series timing belt question? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
Yes.
This has to be lined up, along with the cam gears. Dont use the crank pulley.</TD></TR></TABLE>
Old Oct 9, 2004 | 05:29 PM
Default Re: b-series timing belt question? (JDM CTR '00)
ok thx guys
Old Oct 12, 2004 | 06:42 PM
cvrboi's Avatar
c-speedracing.com helped alot during my belt change
Old Oct 12, 2004 | 09:37 PM
B18C-VTI_R's Avatar
Default Re: b-series timing belt question? (cvrboi)
right on, cspeed is the best place to learn stuff
Old Oct 13, 2004 | 07:24 AM
http://www.c-speedracing.com/h...t.php
Old Oct 13, 2004 | 07:57 AM
cvrboi's Avatar
be sure to line up the cam gears. saves a lot of time and troble. trust me
Old Oct 13, 2004 | 08:01 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cvrboi &raquo;</TD></TR><TR><TD CLASS="quote">be sure to line up the cam gears. saves a lot of time and troble. trust me</TD></TR></TABLE>
I already posted that
You can line up the cams and drop a 5mm pin punch through the cam caps into the cams, and then they wont move at all. its very handy.
Old Oct 13, 2004 | 08:12 AM
MattD@Stoptech's Avatar
You can line up the cams and drop a 5mm pin punch through the cam caps into the cams, and then they wont move at all. its very handy.</TD></TR></TABLE>
Assuming j00 have stock cams...
tannerLSt
Dec 14, 2007 01:58 PM
RTW DC2R
May 23, 2005 10:33 AM
spyderracing
14
Sep 26, 2004 09:10 AM
_jester_
Dec 19, 2003 07:51 PM
flip b18b
13
Aug 11, 2003 11:18 AM
