tdc...should i try to fix this?
Old Oct 9, 2004 | 12:30 PM
R.S.'s Avatar
Default tdc...should i try to fix this?
I have a B18b non vtec and ctr pistons, every thing else pretty much stock
well when my cams are at tdc (the holes on the cams line up and the cam gears line up on the mark on the timing belt cover) the white line on the crank pulley is slightly torwards 1 o'clock 5mm (from the mark on the timing belt cover)
Should i attemp to fix this some how?
Old Oct 10, 2004 | 06:40 AM
R.S.'s Avatar
Default Re: tdc...should i try to fix this? (R-Spec)
any 1?
Old Oct 10, 2004 | 06:55 AM
Dan GSR's Avatar
take off the crank pully and look at the timing mark on the oil pump gear,
it should be about within 1mm of the mark
Old Oct 12, 2004 | 06:02 PM
00s2KkId's Avatar
yea you should fix this soon...get a huge breaker bar for the pulley bolt
ToTriggerHappy
Jan 13, 2011 06:31 AM
dc2leftovers
Dec 10, 2006 08:15 AM
Danronian
Apr 12, 2006 03:06 PM
R.S.
Oct 11, 2004 03:12 PM
WannaHonda
May 6, 2004 10:12 AM
