Brembo front rotors dont fit (93 ex coupe)
Old Oct 9, 2004 | 12:29 PM
magicksdc2's Avatar
Default Brembo front rotors dont fit (93 ex coupe)
i just recieved my brembo OE replacement front rotors from IRP (import replacement parts) and they do not fit on my car. the size is right (9.5"), the lug nut pattern is good, but the back of the rotor will not slip over the hub because the diameter is off by about 1/2 a centimeter too small. has anyone else had this problem happen?
what would you all do in this situation.. obviously im going to return these rotors but i need new front brakes (rotors AND pads) to pass the VA safety inspection and id really like to avoid spending $80 a rotor at honda. id like to get this done in the most cost-effective manner for myself, because the car is being sold once i get it through inspection. thanks in advance.
Old Oct 9, 2004 | 12:38 PM
I_LuvmyHonda's Avatar
Default Re: Brembo front rotors dont fit (MGXcoupe)
get a dremmel or rotary grinding tool of some kind and make it fit...thats your best bet if you dont want to spend the money to have the rotors shipped back and all that good stuff...i had to do the same thing to a big brake kit to make em fit my dx hubs...it worked no problem...just becareful not to go too wide...grind, check, grind, check, grind check...till it fits good
Old Oct 9, 2004 | 12:52 PM
=GAME='s Avatar
are you sure you got the right one? 92-93 and 94-95 civics have different size rotors.
LSvtechatch97's Avatar
Default Re: Brembo front rotors dont fit (I_LuvmyHonda)
walk into NAPA or schucks, they are liuke $30 for OE replacements and they ahve pads too for cheap.
Old Oct 9, 2004 | 01:07 PM
menkio's Avatar
Default Re: Brembo front rotors dont fit (FUKuPAYme)
you would take a grinder to your rotors to make them fit.. please stop touching cars.
Just return it and get the right one...
Old Oct 9, 2004 | 02:24 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MGXcoupe &raquo;</TD></TR><TR><TD CLASS="quote">i just recieved my brembo OE replacement front rotors from IRP (import replacement parts) and they do not fit on my car. the size is right (9.5")</TD></TR></TABLE>
9.5" is NOT the correct rotor diameter. ALL Civic EXes from 1990-2000 use the 10.3" front rotors.
Old Oct 9, 2004 | 03:04 PM
Default Re: Brembo front rotors dont fit (yanta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by yanta &raquo;</TD></TR><TR><TD CLASS="quote">you would take a grinder to your rotors to make them fit.. please stop touching cars.
Just return it and get the right one...</TD></TR></TABLE>
uhhh yeah...its called fabrication...and if you do it RIGHT it wont harm anything...i drove longer than any o.e.m rotor ever lasted me with my big brake kit with no problem and did the same thing....its just an option so he doesnt have to pay for shipping to return the parts he ordered...it cost money to ship heavy *** rotors you know...so blaaaaaahhhhh
Old Oct 9, 2004 | 06:17 PM
Mattamotor's Avatar
Default Re: Brembo front rotors dont fit (=GAMEOVER=)
damn i some times wonder about this webboard
you need 10.3 inch rotor on your EX. Nothing else will work unless you swap caliphers and brakets.
second you can not fabericate the rotors he has to make them fit unless you can add .8 inches of diameter to them.
92-93 and 94-95 rotor are the same, heck even 92-00 civics are the same.
90-00 Civic Ex, 99-00 Si, and all civics with ABS use the 10.3 front rotor. Other honda product that use that rotor include all 90-01 integra(except Type-R), and all Del Sol Vtec. Honda Part number 45215-SK7-A00
88-00 Dx, 89-00 LX, 88-91 CRX DX and SI, 88-95 SI, ALL VX and CX, and all HX.
These are the cars that use the 9.5 brake rotors. Honda part numbers are 45251-SH3-660(non finished surface) and 45251-SRO-990(finished surface).
also big brake kits are just bling for about %90 of the track cars i know, street cars with decent pads and fluid should never fade and brake with in a couple of feet than a "big brake kit".
y2kferari
Jun 12, 2008 05:20 PM
kmaz93da
May 27, 2008 10:51 AM
MUGEN_EG95
Honda Civic (2006 - 2015)
13
Apr 20, 2008 10:15 PM
nerdish
Jul 9, 2001 11:54 AM
