alternative to hondata
Just wondering if there are any other {cheaper} alternatives to hondata. I need something very basic but reliable to tune jsrc on teg. Spent quite a bit of money and am going broke fast! Just need something very basic that will help with management and can be fairly easily tuned. There are so many different types of management ....so just need some advice
here is my jrsc list
JRSC
Spark Plugs
Fuel Pump
Cartech FMU $260new $120used
JR BTC $360 $150
Boost Gauge
Fuel Pressure Gauge
Gauge Pod
Fuel filter
JR Map Controller $150 $100
About $400 if you buy used parts
JRSC
Spark Plugs
Fuel Pump
JR BTC $360 $150
Boost Gauge
Fuel Pressure Gauge
Gauge Pod
Fuel filter
I agree. A lot of people say that you might as well go with hondata because all the right "piggyback" systems cost just as much and give you less stuff to tune.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lanojp1 »</TD></TR><TR><TD CLASS="quote">Uberdata</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jDMJeRk »</TD></TR><TR><TD CLASS="quote">
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ALL MOTOR LS till 4K »</TD></TR><TR><TD CLASS="quote">
As other's have suggested, Uberdata would most likely fit your needs perfectly. Also, I know you mentioned that you've spent quite a bit of money on the setup so far, but I'd strongly advise you not to make one of the most common mistakes -- spending a lot on a nice setup and then skimping on the tuning portion. Tuning is extremely important (especially where FI is concerned), and it doesn't make sense to invest in a setup and then risk engine damage and inferior power output by cutting corners with the tuning. An Uberdata setup is relatively inexpensive (the software itself is freeware) and yet should give you plenty of tunability.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan »</TD></TR><TR><TD CLASS="quote">As other's have suggested, Uberdata would most likely fit your needs perfectly. Also, I know you mentioned that you've spent quite a bit of money on the setup so far, but I'd strongly advise you not to make one of the most common mistakes -- spending a lot on a nice setup and then skimping on the tuning portion. Tuning is extremely important (especially where FI is concerned), and it doesn't make sense to invest in a setup and then risk engine damage and inferior power output by cutting corners with the tuning. An Uberdata setup is relatively inexpensive (the software itself is freeware) and yet should give you plenty of tunability.
Where can you buy this.. Ive heard people talking about this product.
Would you need seperate things to control boost, and feul pressure, or does this unit do it all?
</TD></TR></TABLE>Where can you buy this.. Ive heard people talking about this product.
I really do plan on going hondata very soon. I just hope that the jrsc FMU will last me untill I'm able to get hondata up and running. Everything seems to be ok, but i still am wanting to be POSITIVE on my fuel management. Last thing i want is a pile of money going KA boom. Exaust smells rich, a/f meter showing o.k. fuel pressure is good, ect. the only worry i have is the plugs are a little more white than i would like.......but no detonation sound or anything other than plugs to suggest a lean mixture. my tuner is about 2 hours away and i don't want any problems b/f i can get to him. I've been driving around town for about 2 weeks and have had no problems, but the "little trip" worries me a little:}
Also ...this may be a dumb question but i'll ask anyway. i know jrsc fmu is 5:1 raise,but everyone is saying go Cartec or ect. most of them are 12:1 fuel raise. Can I just switch them out and adjust fuel pressure or do i need to go with a 5:1 disc in the Cartec?
