Problem with turn signal...
Old Oct 8, 2004 | 05:58 PM
_Spugen_'s Avatar
Default Problem with turn signal...
Ok well the car is up and running now and I have a problem with the turn signals...when I go to signal instead of each of them turning on individually they both turn on at the same time...Is it a fuse or something more serious?
Old Oct 8, 2004 | 06:01 PM
SOHC4life 96's Avatar
Default Re: Problem with turn signal... (SpugenEG)
Could be a crossed wire. I really doubt that a fuse would do that. But I dont know for sure.
Old Oct 8, 2004 | 06:06 PM
_Spugen_'s Avatar
I would check the fuses but I dont have the diagram...so does anyone have one??
Old Oct 8, 2004 | 06:07 PM
nxstrikerxn's Avatar
with this seriously its crosswire. Check under your fuse panel under the steering and then check your switch by removing the steering cover and check if the wire looks original or has it been tap; meaning cut or re-wire...
Old Oct 8, 2004 | 06:09 PM
Deemeetree's Avatar
Electrician
Should be a crosswire man. A blown fuse won't turn both on. Let me know if you need any help.
efcivic317
Dec 2, 2010 02:25 PM
k20eklipse
26
Jul 12, 2010 08:55 PM
ChevelleSSLS6
Apr 9, 2009 07:44 PM
Mrx733
Honda Civic (2001 - 2005)
Nov 18, 2006 09:50 AM
deadeyehatch
Nov 20, 2003 11:44 AM
