Intake as good or maybe better than J's Racing Intake
Let the flame war begin.
It's a cheap knock-off. All intakes do the same thing, suck in air. Only difference is the diameter of the piping. I bet you can Mandrel bend a 3" pipe for $5 and it'll gain as much whp as a $300 unit.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimi »</TD></TR><TR><TD CLASS="quote">Let the flame war begin.
It's a cheap knock-off. All intakes do the same thing, suck in air. Only difference is the diameter of the piping. I bet you can Mandrel bend a 3" pipe for $5 and it'll gain as much whp as a $300 unit. </TD></TR></TABLE>
Don't forget some intake piping are more resitant to heat than others.
Motor Heat =
Motor Heat =
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa »</TD></TR><TR><TD CLASS="quote">
Motor Heat =
Ok, so go buy some Heat Resistant paint for BBQ pits for $5 at Wal-Mart. I know NO heat will enter the intake piping now. $10 for a 3" Mandrel bent intake. Slap on a K&N filter...off you go for $50.
Motor Heat =
</TD></TR></TABLE>Ok, so go buy some Heat Resistant paint for BBQ pits for $5 at Wal-Mart. I know NO heat will enter the intake piping now. $10 for a 3" Mandrel bent intake. Slap on a K&N filter...off you go for $50.
It's a cheap knock-off. All intakes do the same thing, suck in air. . </TD></TR></TABLE>
motor's don't 'suck' air.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slammed_93_hatch »</TD></TR><TR><TD CLASS="quote">
motor's don't 'suck' air.</TD></TR></TABLE>
of course they dont, because "motors" are run by electricity. Engines suck in air.. atleast thats what i would call it since its a vacuum force at work.. vacuum's suck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91civicDXdude »</TD></TR><TR><TD CLASS="quote">
engine motor's same difference.
neither of of the suck in air
</TD></TR></TABLE>engine motor's same difference.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eh6 »</TD></TR><TR><TD CLASS="quote">Has anyone ever used this intake before?</TD></TR></TABLE>
Yes
Yes
looks sweet but,
I said intake, not motor.
Reading comprehension = 0wnZ j00.
Ok, so go buy some Heat Resistant paint for BBQ pits for $5 at Wal-Mart. I know NO heat will enter the intake piping now. $10 for a 3" Mandrel bent intake. Slap on a K&N filter...off you go for $50.</TD></TR></TABLE>
this plan actually looks worth trying out.....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeterHsan »</TD></TR><TR><TD CLASS="quote">
this plan actually looks worth trying out.....</TD></TR></TABLE>
Think about it. You can go to your local muffler shop, or even PepBoys (they sell piping) and get yourself a 3 ft. 3" diameter straight pipe. Go to a local shop that do Mandrel bending. Bend it so it fits the engine bay from your throttle body to the back of the headlight. Go to your local Wal-Mart and use BBQ Heat Resistant paint. It blocks until about 2,000* F supposedly (but at least your engine bay probably doesn't go above 150*-200* on a Summer day). Spray liberally. Off you go. I bet it'll work just as good as an AEM.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Revolver »</TD></TR><TR><TD CLASS="quote">Not a bad alternative. Except mandrel bending sucks.....but it's cheap.</TD></TR></TABLE>
You got it backwards h0mi3. Mandrel bends are the best. Crush-bent sucks and is the cheapest.
Mandrel = Equal diameter along EVERY curve.
Crush = Different diameter along EVERY curve.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mwieczorek43 »</TD></TR><TR><TD CLASS="quote">I had a AEM CIA loved it. Go AEM
I didn't know AEM was in the Central Intelligence Agency.
</TD></TR></TABLE>I didn't know AEM was in the Central Intelligence Agency.
I made a mandrel bent intake before for a friend with some high resistant VHT wrinkled paint I had left over for a valve cover and sprayed it on the piping. Then we put on his apexi power filter, slap some apexi sticker on the piping, and called it a day. Looks a lot better and he said it was more responsive than his K&N typhoon intake.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BrokeAssPinoy »</TD></TR><TR><TD CLASS="quote">I made a mandrel bent intake before for a friend with some high resistant VHT wrinkled paint I had left over for a valve cover and sprayed it on the piping. Then we put on his apexi power filter, slap some apexi sticker on the piping, and called it a day. Looks a lot better and he said it was more responsive than his K&N typhoon intake. </TD></TR></TABLE>
Maybe it was that APEX'i sticker.
to answer to question...No, the intake pictured is not comparable to the J's Racing carbon fiber Tsuchinoko intake! You should know that... J's Racing is the ****.
Crush = Different diameter along EVERY curve.</TD></TR></TABLE>
Correct
Correct
Reading comprehension = 0wnZ j00.</TD></TR></TABLE>
well then, intakes don't do ****. except filter, but truly the only part that filters is the filter.
its all symantics i guess
i went with the comptech icabox cause i didn't want to suck up water.
