erratic idle, not charging and hard starting!
Old Oct 8, 2004 | 07:29 AM
cskiff1's Avatar
Default erratic idle, not charging and hard starting!
88 crx hf, the battery will not charge unless the a/c is on or the lights are on. otherwise the battery will only put out 12 volts. without those two on the idle will be really low, like 200rpms, turn the lights on and the idle picks up. also the past two days it takes at least 10 times to fire up. it'll try to start then die. finally it'll catch and run fine. theres lots of knocking in the engine when under a load. other than that its a fine car. any ideas? i've changing the alternator, no help. thanks.
PaulMc
Sep 28, 2013 07:43 PM
B16DelSlo
11
Mar 17, 2009 05:11 PM
teg_95
Jan 10, 2009 12:20 PM
boostcrx89
Jan 13, 2008 07:04 PM
justint
Jan 20, 2007 08:58 AM
