Tuning after compression and displacement change
Old Oct 8, 2004 | 07:27 AM
db2integra's Avatar
Default Tuning after compression and displacement change
I have removed the stock B17A1 motor from my car and built an 8.8:1 compression b18c1 to replace it. I can not afford the turbo kit yet, however I need to get the car back on the road. Is safe to assume that the factory map is safe with this setup? I will be using the stock OBD-1 ecu with the engine.
Old Oct 8, 2004 | 11:46 PM
db2integra's Avatar
Default Re: Tuning after compression and displacement change (db2integra)
BUMP
Old Oct 9, 2004 | 12:06 AM
Sack Master's Avatar
The factory map should be fine. You may want to advance the timing a bit and probably lean it out to get the most power out of it, or at least tinker around with that stuff. But stock settings it should run just fine.
Old Oct 9, 2004 | 08:31 AM
Mase's Avatar
Default Re: Tuning after compression and displacement change (Sack Master)
stock will be fine.
Old Oct 11, 2004 | 08:01 AM
db2integra's Avatar
Default Re: Tuning after compression and displacement change (Mase)
Thanks guys. Motor is mounted and almost ready for startup.
Old Oct 11, 2004 | 09:04 AM
91civicDXdude's Avatar
hook me up with that boring ol' stock b17
Old Oct 12, 2004 | 06:10 AM
db2integra's Avatar
Default Re: (91civicDXdude)
It is for sale, $550 on the short block. It was still blowing 205psi on all cylinders for me when removed.
G2IntegraGS
Engine Management and Tuning
May 2, 2009 05:51 PM
NotPhilTran
Mar 17, 2005 05:40 AM
