Does anyone know how to retain the AC when doing a gsr swap into a 99+ civic, without the use of the
Does anyone know how to retain the AC when doing a gsr swap into a 99+ civic, without the use of the Del Sol (vtec) A/C bracket? Im not sure how to custom it.. or is there a way i can make mines fit. Or can i get one off the gsr and mount tha ton.. i heard that wouldn't fit well. All suggestions are welcomed!
Well let's think for a minute, in 1999 there was a Civic with a B series swap called.............
An Si
Get the 99 Si AC bracket and you can use your AC with the GSR motor.
You can get it cheap at http://www.hparts.com and the 99 Si AC bracket is the same as the 96-97 del Sol AC bracket. I have the part number listed at http://www.jspectuning.com/6gen/
HTH,
An Si
HTH,
AXiONMOTORS
Feb 21, 2009 05:15 AM
raidacaipo
12
Jul 11, 2008 06:57 PM
Tyson Ballou
Dec 14, 2001 11:16 PM
