Where does the CEL located?
Old Oct 7, 2004 | 08:55 PM
valentino2k3's Avatar
Default Where does the CEL located?
Hi! everyone, i'm new at this swap thing and i was wondering if someone tells me or show me where is the CEL on the p28 ecu? i just swap the engine on my crx and now the engine light comes on. i know everybody talks about CEL codes but i don't even know where is located at. So please can someone show me? Thanks
Old Oct 7, 2004 | 09:00 PM
EL Vap133's Avatar
Default Re: Where does the CEL located? (valentino2k3)
CEL=Check engine light.
Old Oct 7, 2004 | 09:04 PM
Default Re: Where does the CEL located? (EL Vap133)
So how do you get the codes on which sensor is faulty?
Old Oct 7, 2004 | 09:06 PM
eda6's Avatar
The p28 doesn't have a led on the ecu like obd 0 ecus. There's a wire you need to ground out on the p28. The CEL will blink on your cluster instead of the ecu. I'll post the pin number when i find it. I really don't know which wire cause i'm still obd 0. Hopefully obd 1 this weekend.
Old Oct 7, 2004 | 09:10 PM
Default Re: Where does the CEL located? (eda6 hatch)
i grounded the check engine light wire and the CEL is blinking.
Old Oct 8, 2004 | 01:08 PM
jedubz's Avatar
search check engine light and learn how to read what those blinks mean.
4DALOOKS92
Apr 16, 2016 07:46 AM
project91crxsi
Feb 20, 2012 07:24 AM
RiipTiide67
Engine Management and Tuning
Jan 16, 2012 06:57 AM
boostd ls
Oct 4, 2009 09:45 AM
superturboprelude
Oct 29, 2003 11:42 AM
