Difference between MIG and TIG
Mig = GMAW (gas metal arc welding) Tig = GTAW (gas tungsten arc welding)
Tig is more controlled in everyway possible, requires more skill, and is slower, and more versatile. Weld anything from carbon steel to titanium. Also less strength.
Mig is less controlled, faster welding, easier. Less versatile. Most widly used on carbon steels.
I could go into SOO much detail, thats just the basics.
can you weld suspension parts together? such as a strut bar with a MIG welder? would it be strong enough? i have a snap on MIG welder and i wanna do some custom fabbing
Someone said you got to weld in a certain direction. what direction or pattern do you make while your mig welding... i bought a 90amp mig welder befor i knew anything.. now i want to get rid of it and get a mig welder with gas instead of rosin core... the welds look ugly as hell..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HamiltonRex »</TD></TR><TR><TD CLASS="quote">Tig is more controlled in everyway possible, requires more skill, and is slower, and more versatile. Weld anything from carbon steel to titanium. Also less strength.</TD></TR></TABLE>
You mean more strength.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyVtec8yourV8 »</TD></TR><TR><TD CLASS="quote">Someone said you got to weld in a certain direction. what direction or pattern do you make while your mig welding... </TD></TR></TABLE>
They were probably talking about the angle your welding at. You want to push the bead, and change your angle to get the best penetration.
Thats what I thought i was welding and constantly moving the arc.. cause i was burnign threw the exaust.(practice peice) so what angle is best?
Gustav129
Welding / Fabrication
18
Jan 27, 2013 07:17 PM
Flashmn
Dec 26, 2006 07:29 AM
Green Street
10
Dec 31, 2003 02:40 PM
