98 gsr with jackson has anyone used a crv crank
Old Oct 7, 2004 | 05:27 AM
chargedgsr99civic's Avatar
Default 98 gsr with jackson has anyone used a crv crank pulley
I have heard that it will put you a about 10 to 11lbs of boost from 7 to 8 does it work and has anyone had any problems?
Modified by chargedgsr99civic at 10:55 AM 10/7/2004
Old Oct 7, 2004 | 06:38 AM
shamoo's Avatar
Will you make something up for me please?
Default Re: 98 gsr with jackson has anyone used a crv crank (chargedgsr99civic)
How will a crank give you more boost?
Do you mean an upgraded pulley for the supercharger?
Old Oct 7, 2004 | 06:54 AM
Default Re: 98 gsr with jackson has anyone used a crv crank (shamoo)
I don't know but it is smaller which will turn the charger faster and the upgrade pulley for jrsc is a crank pulley
Old Oct 7, 2004 | 09:34 AM
yee SERIOUS's Avatar
i heard a friend of mine did it, and it
Old Oct 10, 2004 | 05:15 AM
Default Re: 98 gsr with jackson has anyone used a crv crank (LiTtOGPiMp)
What kind of set up did he have when he had tried the crv pulley.
Motor?
Car?
Year?
charger?
pulleys?
fuel managment?
boost control?
Old Oct 10, 2004 | 11:15 AM
from what i know. gsr, integra, 94, jackson supercharger.
he went from 6psi to like 4 or 2. i forgot which one. i don't know what caused him to run less psi. i thought it was very weird.
Old Oct 10, 2004 | 09:36 PM
Default Re: (LiTtOGPiMp)
Any info would be helpful if you don't mind see if you can find out any more on his set up and if he had another problem that might have coused the loss in boost
Old Oct 11, 2004 | 07:14 PM
larryd's Avatar
Default Re: (chargedgsr99civic)
I just bought my car last week so i don't have full details but from what my Honda buddys tell me I have the JRSC and a CRV crank pulley, I'm putting out about 10-11lbs of boost though its around 12 right now with the colder weather creeping in.
When I talked to Jackson Racing earlier today though they told me that what I have is impossible. They said I have to have a smaller alternator pulley or something but my friends swear its all stock cept the CRV crank pulley.
Old Oct 11, 2004 | 07:35 PM
Finger Lickin' good's Avatar
Default Re: (larryd)
why use a crv pully? Endyne makes pully's for the JRSC up to 14 psi. Granted the teflon wrap on the rotors will flake off, but thats why JRSC sucks. If you supercharge, go vortech. BEST overall design, MOST expensive.
Old Oct 12, 2004 | 08:30 AM
iwhichisme's Avatar
Default Re: 98 gsr with jackson has anyone used a crv crank pulley (chargedgsr99civic)
had a friend who put a crv pulley on an 99si. It put the boost somewhere around 10psi. Worked prety well for a little while, until he eventually blew his motor. Ran a best of 12.9. The crv crank pulley is actually larger, which turns the supercharger a bit quicker.
Old Oct 12, 2004 | 02:36 PM
larryd's Avatar
Is it suggested to go with something like the Endyne setup instead of doing the CRV pulley?
Old Oct 15, 2004 | 05:05 AM
Default Re: (CeReaL);(larryd)
So how long have you had the crv pulley on your set up? I'm not worried about my motor i just had it rebuilt with forged pistons and rods type r intake valves and stiffer valve springs. I'm more worried about the charger which has just been rebuilt and then replaced by magnuson after the rotor bearing was defective and locked up the charger. I also have a aem ems and warbro fuel pump with 440 injectors. Never the less i have a a new crv pulley from honda but thinking about returning it and getting the JRSC crank pulley which is only 2 to 3 lbs where jackson says that the crv pulley should make about 3 to 4 lbs. So what do you think i should do?
Old Oct 15, 2004 | 08:16 AM
larryd's Avatar
That would be up to you. I'm actually contemplating taking mine off and just putting the stock pulley back on as I'm pushing 12lbs right now and its only going to keep going up as it gets colder.
LUKE 92 GS-R
Aug 21, 2012 04:14 AM
ghostriderinnc
May 13, 2010 10:22 PM
suprchrg95
May 17, 2004 01:10 PM
fredtoast
Dec 3, 2002 11:16 AM
Replica
Dec 3, 2002 04:42 AM
