Question about oil filter....
u should change it everytime u change ur oil, and there are a number of brands just go into pepboys tell the service counter what make and model and theyll give u the filter number for it i have a 93 gs and mine was 3$
From: Salt Lake City, Chicago at heart, UT or IL, USA
I change every oil change. I use whatever the place uses that changes my oil. (I get 5.00 oil changes, penzoil, and not sure about the filter. I think it's nappa or something like that)
change filter everytime you change the oil.
i use filters manufactured by Wix. the Napa Gold filters are made by them, not sure who else's are.
btw.......penzoil is junk. it's a wax based oil and doesn't work for ****. technicians at the mazda dealer i worked to insisted on switching away from it.
techinically u can change oil filter every 2 oil changes
but thats from the manual where they tell you that you can run on 1 oil change for 12K miles...and change oil filter every 24K miles
umm I thought the oil itself could go for longer intervals than the filter... for instance a certain oil might be good for 10K miles, but the filter might get clogged up after 5K miles and just send the oil through the by-pass instead of filtering it. Of course at this point you would need to change both the oil and filter because the oil has gotten very dirty (since the filter is no longer filtering the oil), but if you change the filter before 5K then you could go 10K before changing the oil.
That's just what I understand from reading, though. I personally use Valvoline MaxLife 10w30 and STP filters changed every 3K.
kidcool1977
Oct 27, 2008 05:40 AM
