bent valves....should pistons be replaced?
Old Oct 6, 2004 | 06:56 PM
mitsuman's Avatar
Default bent valves....should pistons be replaced?
have any of you ever bent some velves and not had to replace the pistons? cuz im thinkin of buyin a motor with bent intake valves. i dont mind replacing the valves, but i dont wanna have to replace the pistons. seller states that the valves arent that bent. thanks for the info.
Old Oct 6, 2004 | 06:59 PM
The Destroyer's Avatar
Default Re: bent valves....should pistons be replaced? (mitsuman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitsuman &raquo;</TD></TR><TR><TD CLASS="quote">have any of you ever bent some velves and not had to replace the pistons? cuz im thinkin of buyin a motor with bent intake valves. i dont mind replacing the valves, but i dont wanna have to replace the pistons. seller states that the valves arent that bent. thanks for the info.</TD></TR></TABLE>
It depends if there is any damage to the pistons. If there is no damage to the pistons, I dont see why it would be a problem.
Old Oct 6, 2004 | 07:01 PM
mitsuman's Avatar
Default Re: bent valves....should pistons be replaced? (Vtaaak y0)
but i mean is that even possible? bending valves with out damaging pistons?
Old Oct 6, 2004 | 07:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mitsuman &raquo;</TD></TR><TR><TD CLASS="quote">but i mean is that even possible? bending valves with out damaging pistons?</TD></TR></TABLE>
Yeah, I think I just had a brain fart. The dude that had my car before me fucked up the pistons in a weird way, yet the valves are fine. (skipped like 3 teeth)
Old Oct 6, 2004 | 08:05 PM
mitsuman's Avatar
thanks for your info.
anyone else?
Old Oct 6, 2004 | 08:15 PM
Rusty Shackleferd's Avatar
If the pistons have little dings in them you can get at them with a 3M pad (depending on how bad the dings are). I would change the rod bearings also.
Personally I wouldn't buy the motor unless the head was taken off so you could see the damage.
Old Oct 7, 2004 | 06:17 AM
mitsuman's Avatar
Default Re: bent valves....should pistons be replaced? (Rusty Shackleferd)
^^ thanks
phirewire
Jun 28, 2011 12:28 PM
hYbRid_Eg6
Feb 7, 2011 09:36 AM
1A4
Mar 28, 2008 01:18 PM
gs1gsr
Jan 9, 2008 09:30 PM
Rhythm
Mar 19, 2006 07:33 PM
