wirring problem
Old Oct 6, 2004 | 04:10 PM
1990hf's Avatar
Default wirring problem
How do i wire a 92 CX motor to a 91 SI?
Old Oct 6, 2004 | 05:09 PM
zCivic's Avatar
Default Re: wirring problem (1990hf)
just take the engine harness of your SI engine and the Diz and put them on the D15B. Seeing its a 92 motor you can either use the coolant temp sensor in the termostat housing or remove a plug in the back and take the one out of the SI block. If you use the one in the thermo housing will need to change the plug type and extend the wires.
Old Oct 6, 2004 | 05:24 PM
1990hf's Avatar
Default Re: wirring problem (zCivic)
thanks alot for the help but i forgot one more question on the post.
Would the 92 CX ECU plug rite into my ECU harness?
thanks.
Old Oct 6, 2004 | 05:32 PM
zCivic's Avatar
nope...I would suggest reusing your SI ECU or you'll have to get a jumper haness
Old Oct 6, 2004 | 05:36 PM
1990hf's Avatar
how much would the jumper harness be?
thanks again
4g4dcruisin
Mar 12, 2010 04:25 PM
Boricuanology
Aug 29, 2006 09:21 AM
