Head Gaskets???
Old Dec 14, 2001 | 10:34 AM
InfamousRS's Avatar
Default Head Gaskets???
I plan on going with Golden Eagle sleeves with a 84.5mm bore. What will I do for a headgasket? Will I use a oem b20 head gasket, or an aftermarket coper or metal head gasket? I will be running lots of boost, and useing a b16, or b18c head.
Old Dec 14, 2001 | 10:37 AM
B18C-EJ1
Guest
Posts: n/a
Default Re: Head Gaskets??? (BLK94RS)
You can get them up to 85mm in size from Cometic.
http://www.nrg-racing.com has them. But you have to ask for it.
Old Dec 14, 2001 | 10:44 AM
InfamousRS's Avatar
Default Re: Head Gaskets??? (B18C-EJ1)
What are the Cometic head gaskets made out of? Will they hadle lots of boost?
Old Dec 14, 2001 | 12:23 PM
sgT's Avatar
sgT
If you are using a b18A/B then you can use the CRV head gasket.
Old Dec 14, 2001 | 12:42 PM
InfamousRS's Avatar
Default Re: Head Gaskets??? (sgT)
Will a OEM head gasket handle lots of boost?
Old Dec 14, 2001 | 12:46 PM
Spade's Avatar
I would just get a copper from summit or somewhere and have it bored to 84.5 as well. Lots of boost usually needs a metal headgasket.
Old Dec 14, 2001 | 12:48 PM
SkotEZ's Avatar
The stock head gasket will handle boost quite well. On the several boosted hondas i've built I've never use anthing but a stock head gasket.
Old Dec 14, 2001 | 12:49 PM
SkotEZ's Avatar
Default Re: Head Gaskets??? (Spade)
Factory Honda gaskets are metal.
Old Dec 14, 2001 | 04:38 PM
TurboSedan's Avatar
New User
Default Re: Head Gaskets??? (suprfast)
Where's jinxprrof99 in this thread?
Old Dec 14, 2001 | 05:12 PM
MrFatBooty's Avatar
Default Re: Head Gaskets??? (97CivicFerio)
Race Engineering has the Cometic gaskets, among other things.
Old Dec 14, 2001 | 09:57 PM
TECH43 RACING INC.'s Avatar
Default Re: Head Gaskets??? (MrFatBooty)
A COMETIC GASKET IS GOOD..BUT ONLY NECCESSARY WHEN A BIG BORE VTEC BLOCK IS USED B16/17/18C. (WHEN VTEC OIL PRESSURE IS FED THROUGH THE BLOCK)
WHEN USING A NON VTEC BIG BORE BLOCK ..YOU CAN USE A CRV HEAD GASKET ON BORES UP TO 85MM
.... THE BEST SEALING FOR TURBO: HAVE VINCE @ GOLDEN EAGLE MACHINE YOU A .002-.003 STEP DECK AND RUN A CRV GASKET...YOU WILL HAVE NO PROBLEMS..AND DON'T O-RING YOUR BLOCK!
Old Dec 15, 2001 | 09:28 AM
Rain_man's Avatar
New User
He probably doesn't visit the Tech forum or else he's be all over this!!!
Old Dec 15, 2001 | 09:50 AM
TurboSedan's Avatar
New User
Default Re: Head Gaskets??? (Ein)
I'll have to IM him and tell him about this one, hehe!
Old Dec 15, 2001 | 02:16 PM
InfamousRS's Avatar
Why would Jinx be so interested in this post? Does he not believe in head gaskets at all or somthin?
Old Dec 15, 2001 | 03:03 PM
Rain_man's Avatar
New User
Visit the FI forum and you'll know.
He claims with his inlinepro head gasket you can run 18 psi on a stock engine using a VAFC and FMU. That's what his setup is at least and he puts out 350 hp.
Old Dec 15, 2001 | 06:02 PM
InfamousRS's Avatar
Thats assuming your using a b18c1 engine with the stock fairly high compression pistons. The InlinePro Head Gasket just lowers the CR of the engine to alow you to boost more. I don't think it would beneficial in my setup.
Lx Civic 99
Dec 31, 2013 05:50 PM
hamizle
Dec 1, 2009 04:55 PM
Kris's turbo
Jun 6, 2008 07:40 PM
ArtNerd
Sep 4, 2006 07:57 AM
StreetEG
Jul 7, 2006 08:45 PM
