Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Inexpensive higher pressure rad cap?
Old Oct 6, 2004 | 03:13 AM
jlucas's Avatar
Default Inexpensive higher pressure rad cap?
Would be interested in trying one on a project car but not at the price of a Mugen. Any suggestions for a lower cost alternative?
Old Oct 6, 2004 | 05:12 AM
Crack Monkey's Avatar
Default Re: Inexpensive higher pressure rad cap? (jpl95si)
I'm wondering why you would want/need one? With the proper radiator, I wouldn't think you'd have to worry about increasing water pressure.
Old Oct 6, 2004 | 06:15 AM
.RJ's Avatar
.RJ
Only if it comes with a matching high-pressure oil cap
Old Oct 6, 2004 | 12:03 PM
95dc2's Avatar
Default Re: Inexpensive higher pressure rad cap? (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Only if it comes with a matching high-pressure oil cap </TD></TR></TABLE>
awe yes, twice the bling......
RJ owns this forum, thank goodness.
Old Oct 6, 2004 | 12:07 PM
Todd00's Avatar
I said I don't want a title!
Think Stant makes some higher pressure than stock caps.
Old Oct 6, 2004 | 12:48 PM
.RJ's Avatar
.RJ
Default Re: Inexpensive higher pressure rad cap? (95dc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dc2 &raquo;</TD></TR><TR><TD CLASS="quote">
awe yes, twice the bling......</TD></TR></TABLE>
Of course
Old Oct 6, 2004 | 03:56 PM
pmachan's Avatar
Default Re: Inexpensive higher pressure rad cap? (Crack Monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crack Monkey &raquo;</TD></TR><TR><TD CLASS="quote">I'm wondering why you would want/need one? With the proper radiator, I wouldn't think you'd have to worry about increasing water pressure.</TD></TR></TABLE>
I started a post on this and got no response, maybe I can here..
I have increasing water pressure on the track in my stock B16, doesn't overheat, just builds pressure and fills the overflow and then bubbles. All plus look fine, car doesn't lose a drop of coolant otherwise.
What could be causing the pressure? The car is new to me and had a new rad installed just before I got it, everything looks fine.
Anyone?
Old Oct 6, 2004 | 04:43 PM
jlucas's Avatar
It's not for cooling, got plenty of that. The theory I'm working under is the increased pressure will reduce the cavitation that can occur with extended high RPM operation.
Old Oct 6, 2004 | 07:20 PM
CRX-RX's Avatar
What pressure are you looking for? I'm currently using a 1.1bar NSX cap on my CRX. The best part about it was that the NSX cap has a different part # vs comparable units, but also has a silicone seal vs the usual rubber unit It's geeky, but hey, I needed a new cap anyways
Old Oct 6, 2004 | 08:01 PM
FF lotus's Avatar
Default Re: Inexpensive higher pressure rad cap? (CRX-RX)
All it's supposed to do it raise the boiling point of water a bit. For people running zero coolant and all water or runing hot ect it sounds like cheap insurance
prelude_93vtec
Jul 9, 2007 06:43 PM
importdude2000
Sep 8, 2006 08:55 PM
mickey513
Oct 11, 2004 06:51 AM
96 Ls lnTeG
Jan 9, 2004 09:19 PM
turbospool
May 1, 2003 10:09 PM
