Strange timing problem....HELP!
Old Oct 5, 2004 | 11:45 PM
wickedEFguy's Avatar
Default Strange timing problem....HELP!
first off I just swapped a B16 into a 88 CRX DX, I have already converted to MPFI and traced all the wiring. here's what it's doing........
when trying to time the car with a timing gun I have to completely advance the dizzy and it's barely coming close to the 14 degree mark on the crank pulley. I know about the little paperclip thing you have to use that's on the drivers side and I've tried with it and without it, still not luck.
When trying to drive the car it acts like it's not getting any timing what so ever like as if the Crank angle sensor has gone bad or something. It isn't throwing any codes and idles fine, I've also tried 2 good know ECU's on my car (90 CRX Si, B16 swap)and the dizzy's and they seem to be working fine.
I have also checked cam timing and it was directly on so that shouldn't be a problem.
Is there something that I missed or overlooke dwhen I had converted to MPFI?
any advise is welcome........Thanx in advance
Old Oct 6, 2004 | 12:55 AM
Dyn0speed's Avatar
Default Re: Strange timing problem....HELP! (wickedEFguy)
did u ground the scs connector when timing?
Old Oct 6, 2004 | 02:46 PM
Default Re: Strange timing problem....HELP! (Dyn0speed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dyn0speed &raquo;</TD></TR><TR><TD CLASS="quote">did u ground the scs connector when timing?</TD></TR></TABLE>
what? I thought you were just supposed to use a paperclip to jump the 2 terminals? 88-89 the jumper is on the drivers side in the engine bay and 90-91 the terminal is on the passengers side near the glove box.........Why would I have to ground it?
MastaFlyMason
Feb 22, 2019 11:32 AM
Derrick_12341
Aug 10, 2018 07:03 AM
KenJoTuning
10
May 30, 2012 01:15 PM
SLO Sol
May 8, 2006 05:41 AM
