jdm k20a engine stamp: differences?
Old Oct 5, 2004 | 10:30 PM
k20choie's Avatar
Default jdm k20a engine stamp: differences?
Does anyone know how to tell a jdm base DC5/EP3 motor from a jdm itr motor? I believe the engine stamp is the same as with the B-series motors, so is there any solid proof of a motor being an itr?
Old Oct 5, 2004 | 11:09 PM
RsxVengeance's Avatar
i believe the block is stamped with engine code.
BlueIntegraBoy's Avatar
Default Re: jdm k20a engine stamp: differences? (k20choie)
K20A Base = plastic intake manifold, silver valve cover
K20A R = metal intake manifold, red valve cover
Old Oct 6, 2004 | 04:55 AM
Nikos's Avatar
Default Re: jdm k20a engine stamp: differences? (BlueIntegraBoy)
The stamp under the throttle body on block should say K20a.
On belt side there should be a sku # that also says K20a.
Vtec solenoid on type r does not have a pressure switch beside solenoid on top unlike Type s and possibly others.
black dip stick
I vtec cover just says I VTEC and under is DOHC ONLY
Old Oct 6, 2004 | 12:09 PM
stealthhatch's Avatar
all usdm motors will have k20a3, or k20a2 stamped on them. all jdm motors lack the third character (3 or 2) hence k20a.
Old Oct 6, 2004 | 12:16 PM
Default Re: jdm k20a engine stamp: differences? (stealthhatch)
I believe he's asking how to tell the difference from a Integra Type-R and Integra Type-S (the new Integra iS) engines if both blocks are stamps K20A.
Old Oct 6, 2004 | 04:21 PM
k20choie's Avatar
Exactly my point...K20A is all it reads on JDM blocks I believe. Besdies physical things that people can add, such as: the intake manifold, dip stick, valve cover, etc., Is there a stamp on the block with a number unique to the ITR? Anyone know? Thanks for the help guys.
Old Oct 6, 2004 | 08:19 PM
There's a sticker I believe on the timing chain cover. On it, it should say something like:
2PRC-0A01E 267 1
K20A-3604483
OR
2PRB-AA000 270 1
K20A2-14022221
PRB = Type-S ECU
PRC= Type-R ECU
PNF = Base ECU
Old Oct 6, 2004 | 09:25 PM
k20choie's Avatar
Thanks Blue. I also found that PRC meant the itr motor on ebay. I just hope its not that easy to fake...but it probably isnt that hard to print out another sticker and peal off the old one. However, this may have to do until someone finds a better way to ID the itr.
Old Oct 6, 2004 | 10:11 PM
I don't think anyone would go to such trouble and fake an ITR motor.
Old Oct 7, 2004 | 06:38 PM
k20choie's Avatar
I really hope no one would try to fake it.
jroros
Nov 5, 2011 01:19 PM
teddy_dc2
May 18, 2006 07:01 PM
vlc92189
Apr 27, 2006 02:17 PM
derblott
15
Mar 8, 2006 08:23 AM
dr_evil2005
Nov 18, 2004 08:36 AM
