Car bogged while accelerating on freeway, and then it died
Old Oct 5, 2004 | 10:15 PM
young grasshoppa's Avatar
Default Car bogged while accelerating on freeway, and then it died
I was driving on the freeway tried to accelerate (in 5th) and it was bogging so I tried 4th still bogged (about 3k). I was able to maintain a speed of 70 or so. I put the car in neutral and I was still unable to rev past 3500. When I got off the freeway the car died I was able to start it while I still had a bit of momentum and then it died again. I pushed the car to side of the road and was still unable to start the car. It was dark and I was only able to check the battery voltage (12v) and saw that I had fuel pressure. Please give me any suggestions before I have it towed to the mechanic . Car is a 98HB with JRSC and MSD.
Old Oct 5, 2004 | 10:31 PM
WhiteEG6's Avatar
I had a similar problem a few months ago. It turned out to be that my O2 sensor was disconnected.
Old Oct 5, 2004 | 10:42 PM
Default Re: (WhiteEG6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WhiteEG6 &raquo;</TD></TR><TR><TD CLASS="quote">I had a similar problem a few months ago. It turned out to be that my O2 sensor was disconnected.</TD></TR></TABLE>
Did it cause your car not to start also???
Thanks
Old Oct 5, 2004 | 10:43 PM
turbotime's Avatar
any cel's?
Old Oct 5, 2004 | 10:57 PM
Default Re: (turbotime)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turbotime &raquo;</TD></TR><TR><TD CLASS="quote">any cel's?</TD></TR></TABLE>
No CELs
Thanks
Old Oct 5, 2004 | 11:30 PM
SASIR2's Avatar
Default Re: Car bogged while accelerating on freeway, and then it died (young grasshoppa)
Probably something with the distributor, a bad coil maybe. I had a similar problem last year and thats what was the problem.
Old Oct 6, 2004 | 01:09 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: Car bogged while accelerating on freeway, and then it died (SASIR2)
Ya I'd say it's ignition related....could be your MSD box as I've seen them crap out after they are a few years old. How old is yours?
Old Oct 6, 2004 | 01:29 AM
stockegsix's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SASIR2 &raquo;</TD></TR><TR><TD CLASS="quote">Probably something with the distributor, a bad coil maybe. I had a similar problem last year and thats what was the problem.</TD></TR></TABLE>
bingo. or fuel related
Old Oct 6, 2004 | 02:31 AM
H.A.R.T B18C1EG6's Avatar
Default Re: Car bogged while accelerating on freeway, and then it died (stockegsix)
yeah could be ignition problems
Old Oct 6, 2004 | 05:22 AM
Sobe_Death's Avatar
stupid question, but did you run out of gas?
Old Oct 6, 2004 | 10:17 AM
00Red_SiR's Avatar
All Motor Mentor
Default Re: (Sobe_Death)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sobe_Death &raquo;</TD></TR><TR><TD CLASS="quote">stupid question, but did you run out of gas?</TD></TR></TABLE>
If you read his original post you'll see that he said he had good fuel pressure...
Old Oct 6, 2004 | 06:12 PM
Default Re: (00Red_SiR)
Problem solved... The MSD Blaster SS Coil died. I replaced the coil and the car started right up. I like that in the troubleshooting (of the MSD) that one of the first steps is to replace the coil with a good one. This is not always easily done when your broken car is your only mode of transportation and you cannot just buy the coil anywhere.
I have had the system for about 2 1/2 years. I guess this is the life expectancy of a coil. Thanks to all those who helped.
cheedo
May 30, 2007 02:51 PM
nbcivic
May 5, 2006 07:03 PM
DAcraze
Mar 3, 2006 06:22 PM
daklown
May 28, 2005 09:15 AM
Calavera
Jul 10, 2003 04:02 PM
