Crazy temp gauge making car run rich?
I have a DOHC ZC... put about 8k since i swapped the motor.
While doing the swap a guy ripped the wires apart that was connected to the temp sensor, (don't know what happened that caused him to rip it was at a shop), but he said he fixed it. The temp gauge only goes up when hitting some stop signs, or lights.... if i don't the temp doesn't go up at all, if I hit a lot of traffic the temp gauge shoots all up to the to until I start to move.
The car now is blowing a lot of black smoke when going at full throttle, puffs a small bit when accelerating normally. But it wasn't doing this when i first swapped the motor. Is the temp gauge causing this problem?.... but the temp gauge has been going crazy since i put the motor in?
if it helps, my coolant temp sensor is broken right now. its throwing a code 6 i believe, and the CEL. and yes, all i see is green on the a/f ratio cause the car is running full rich since it broke.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Brownjd »</TD></TR><TR><TD CLASS="quote">if it helps, my coolant temp sensor is broken right now. its throwing a code 6 i believe, and the CEL. and yes, all i see is green on the a/f ratio cause the car is running full rich since it broke.</TD></TR></TABLE>
with which guage?
Autometer = Christmas tree... the colors are just pretty.
with which guage?
My CEL is like a women it has PMS it comes on for like 5 sec while driving, once a month, scares the **** out of me...but it throws no codes.
BlackDeuceCoupe
Dec 10, 2002 04:22 AM
