Fuel pump just stoped after installing a FPR?
From: Murfreesboro, Tennessee, United States of America
Its to dark for me to work on the car for now so i thought i would ask all of you for any thing to look for, try, or replace.
I just put on a B&M FPR and now the car will not start.
My fuel gauge showed only at 20 which stock is 40 so i put it at 40 and try to start the car and it fall to 20?
Then it hit me that i couldn't hear my fuel pump. so you would think o well your 13 year old fuel pump just went out but i just replaced it last week with a walbro and it worked great.
So i was wanting to know what this could be?
also where are my fuel relays could they go bad?
thanks guys any comments would help.
follow the instructions on how to test the main relay and fuel pump.
http://www.binghamtonlife.com/...s.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 99sonicbluegsr »</TD></TR><TR><TD CLASS="quote">There u go chris messing up your damn car again!</TD></TR></TABLE>
hey rich
i dont belive your crx is running ..
well i check the fule relay and thats not it so
what do i do now just drop the tank and jack off
cuz it pissin me off
hey rich
Oh its running. Just so happens it is running like ****. But that's ok I have some parts on the way and the motor is coming back out for a lil while. Ill be ready for you in a couple of months chris. We are going to run this town with the d-series!
u try to check fuses???
or the main relay???
if not I would try to send direct power to the pump it's self to see if it will work
these are simple things to think of instead of talking trash to the members on here u are speaking of
a great way to make friends though
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by krazie1 »</TD></TR><TR><TD CLASS="quote">u try to check fuses???
fuses checked all fuses under kick panale and hood - are there any others?
main relay checked and replaced
direct power ---- so run a wire from the + side of the battery to the fule pump and run a wire from the - to the other side ?????? is that what you are talking aboult -or is there a better way?
and what the hell are you talking aboult talking trash? what are you talking aboult man?
</TD></TR></TABLE>fuses checked all fuses under kick panale and hood - are there any others?
http://cgi.ebay.com/ebaymotors...=WDVW
this is the pump i have
i just ran direct power to the pump and after gas flow all up in my face and all over me i see that it work so correct me if i am wrong but now its down to one of these
wires some where
fuse some where i will go check them agin
what else?
wires some where
what else?
NovaRex
Dec 4, 2015 05:10 PM
4doorcivic9
Jun 11, 2008 06:31 AM
