91 lx brake m/c problems
Old Oct 5, 2004 | 04:23 PM
forlorn76's Avatar
Default 91 lx brake m/c problems
alright mine went bad in my lx but I'm going to do a rear disc swap ..so i put in a 1 inch from an ex it needed a new fitting to work so i did all that ..now my brakes are worse..any idea's...and yes they were bled and the m/c was bench bled..thanks
Old Oct 5, 2004 | 05:12 PM
KatyHonda's Avatar
Default Re: 91 lx brake m/c problems (forlorn76)
You need to make clearer the exact nature of your problem. What is a "1-inch"? Do you have a soft pedal, pedal that gradually settles under foot pressure, or brakes locking up?
regards
Old Oct 5, 2004 | 05:14 PM
forlorn76's Avatar
Default Re: 91 lx brake m/c problems (KatyHonda)
1" master cylinder..pedal travels like the m/c is still broken..
Old Oct 6, 2004 | 03:21 AM
KatyHonda's Avatar
If you build up pressure and you gradually feel loss of pressure while holding the brake, the MC, a hose, or caliper is leaking somewhere. MC can leak internally w/ no loss of fluid. If you're not loosing fluid, MC is fault.
good luck
the soL that could
Suspension & Brakes
May 21, 2006 07:18 PM
Integraxnyc
Apr 13, 2004 02:19 PM
crx1856
Aug 17, 2003 04:26 PM
Driven
May 26, 2003 03:29 PM
TedR719
May 21, 2003 07:54 AM
