How does this happen (HELP)
Old Oct 5, 2004 | 03:32 PM
Mr HYDE's Avatar
Default How does this happen (HELP)
i had super low compersion in my motor going from 4 -1 120, 120, 100, 220. so i figured rings i took the motor apart found the valves are all good, and the cylinder walls all look perfect. so i pulled the pistons out while pulling them i notice the pieces of piston falling in my hand.....YAY
here is one of the 3 cracked pistons all of them looking simaliar
here is the top of the same piston as follwed they all look the same
Modified by Mr. HYDE at 3:21 AM 10/18/2005
Old Oct 5, 2004 | 03:35 PM
Super Chicken's Avatar
Default Re: How does this happen (snkyBLOO)
More likely than not it was caused by detonation. You might want to put a knock sensor on your motor or lower your compression ratio or at least not advance your timing so far.
Tryin2Rip
11
Oct 12, 2007 02:39 PM
x2gold
May 16, 2006 05:10 PM
