car bogs after 7k
Old Oct 5, 2004 | 02:01 PM
xtrafastcivic's Avatar
Default car bogs after 7k
car is bogging after 7k rpm.. seems like a it's misfiring.. just wanted to hear inputs on it ..
Old Oct 5, 2004 | 02:36 PM
perlmeister8's Avatar
Default Re: car bogs after 7k (XtraFastCRX)
Fuel cut off? Rev limiter?
Old Oct 5, 2004 | 02:53 PM
Default Re: car bogs after 7k (perlmeistere81)
i've been past 8k b4 with no problems.. and to add some info this started to happen after i installed a fpr.. but the settings are stock .. i returned it back to stock because of the bogging..
Old Oct 5, 2004 | 03:29 PM
IVI's Avatar
IVI
try putting your originial fpr on and see if it makes a diffrence.
a bog after 7k indicates a fuel deliverly problem or a insufficient spark.
if you changed your fpr i would assume it has something to do with that, so i would check that first and then go on from there.
2kdrift
Apr 10, 2013 12:16 AM
RotiEatter
May 29, 2008 03:36 PM
TeamCracka
31
May 7, 2004 05:36 PM
ceasar of mgineering
Jan 24, 2004 02:20 AM
Rwecked
Jun 25, 2003 05:46 AM
